12.0 - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 08-30-2011, 03:13 AM
sleepingciv's Avatar
0/11 sssss1936
Feedback Score: 31 reviews
Default 12.0
Ok so I just watched the youtube vid of the beast.
It said its a 12 volt amp, and not to go over 16v on it.
So when they say make sure ya have the proper electrical what that mean?
Sorry if it sounds like a dumb question i just want to know.
Old 08-30-2011, 03:23 AM
grocerygetter's Avatar
New build coming soon?
0/11 ssssss583
If you're running a 12k rms amp you need an alternator(s) and batteries that can handle the amperage pull.
Old 08-30-2011, 09:36 AM
0/11 ssssss749
Feedback Score: 21 reviews
to make sure you arent starving the amp electrical wise like not enough batts or upgraded alt or alts and not to use 16 volt batts id image if it shouldnt go over 16 volts
Old 08-30-2011, 05:34 PM
SPL Distribution Owner
0/11 sssss2983
this isn't no exceptional amp...
Running 12,000w regardless of amp combo or who makes it, you better have a strong electrical system if for daily.
Old 09-11-2011, 01:41 AM
0/11 ssssss267
if you have to ask these types of questions you should not be buying an amp of this caliber. You will just end up with a broken amp very fast. Do some research and keep asking questions. good luck
TEAM ICE
2 15" DD Z's
4 AB 1100.1's
1 03 Ford Explorer
2011 Db Drag WF SSNW
4th place in the World
Old 09-11-2011, 02:00 AM
toad559's Avatar
0/11 sssss1508
make it easy, get as many ho alt as u can. if only one then get the strongest availble for daily if thats your purpose. then grab at least 6 d3100(examples) do the big 3 and have the proper runs to the amps. get a charger for the bats. no matter what your gonn need to charge it to top it off. alt can only do so much. even if you dont dip below 13v. i run 2 dc 9ks on 1 200 amp alt. but i have 8 0/1 runs and 11 batts and charger to charge it weekly. jus gotta be smart n ur electrical and equipment. but that should be a good start.
