CJs DC F150 6 15s and 10k+ - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 09-15-2011, 12:05 AM
Droppin' HZ Car Audio
0/11 sssss1596
Feedback Score: 26 reviews
Default CJs DC F150 6 15s and 10k+
I finally decided to step up my game to the wall level. Thanks to Rusty, Ana, and Rob for providing the great products that are making this build possible.
First off the equipment list:
6 DC Level 3 15s
1 DC Level 3 10
1 DC 7.5k
1 DC 1.2k
2 DC 175.4
4 Sets AA Carbon Mids- Just picked up 2 more sets today.
4 Sets Kicker SS Tweeters
1 XS D6500 Under Hood
1 XS D3400 Back
1 XS D680 In truck
Charged by Iraggi 260a alt installed in stock location.
5 XS D1400
Charged by Mike Singer 350a alt installed in dual location.
Dakota Digital Volt Meter.
On to the pics.
Old 09-15-2011, 12:06 AM
0/11 sssss4519
6 15s and one 10?
To find sealed resonance
resolve Vas/28.32 =
result of that +1
square root that result
Old 09-15-2011, 12:07 AM
0/11 sssss1596
5 XS D1400s
XS Power 14v Intellicharger
Got lucky and the buss bars I built for my old 3400s will fit these perfectly.
50' each of 4ga and 100' each of 8ga Knu Konceptz wire
2 pieces of 18"x24"x1" Plexi
DC Level 3 10
DC 1.2k
Mike Singer 350a alt- This ***** is HUGE!!!
Old 09-15-2011, 12:08 AM
0/11 sssss1596
Build has officially started. First on my list to do was to swap the dual alternator out for a new Mike Singer 350a unit.
Singer on the Left, Mechman 270 on the right
Installed
Mechman Adjustable voltage
2 runs of 2/0 Welding wire running to the back 14v batteries
Front D6500 running on the stock location iraggi 260.
Stinger sent me a nice message with my volt meter
Old 09-15-2011, 12:09 AM
0/11 sssss1596
Wall is starting to go up.
Old false floor and amp rack
Start of the new floor
Stripped the old dynamat
Second layer of back wall getting primed and painted
More coming.
Old 09-15-2011, 12:10 AM
0/11 sssss1596
Goal for today was to get the Second layer of the back wall installed, build the floor and get one side built and installed.
Passenger side
Old 09-15-2011, 12:11 AM
0/11 sssss1596
Plexi Window
In the truck
Thats is for tonight. Tomorrow I will get the drivers side and top built and installed.
Old 09-15-2011, 12:13 AM
0/11 sssss1596
More done today.
Passenger side brackets installed and side mounted in truck.
Assembly of the driver side.
Outer piece is wrapped and inner piece is painted blue
2 1/2" sandwich pieces to go around the plexi.
Both sides now installed
Top installed
Bottom 45 started
That is all I have for now. The bottom 45 is drying and will be installed today. I may try and get the top side corners installed today as well.
Old 09-15-2011, 12:14 AM
0/11 sssss1596
The shell is 99% done.
I have 6 corners that do require so small glassing, 4 on the bottom 45 where I had to notch around the bolts and brackets and 2 on the top side corners. I will get that work done tomorrow and get the front baffle planned out. Kind of burnt out after 4 days of work on this thing so tomorrow will be a nice easy day. I should have the front baffles cut and installed on Sunday and have everything ready for the arrival of the subs and amps on Wednesday.
Old 09-15-2011, 12:19 AM
0/11 sssss1596
Todays project is glassing the corners and getting it all sealed up ready for the front baffle and bracing tomorrow.
Once the glass has dried, I will be adding some more on the outside in the top corners where you can see the gap in the last pic.
It will get sanded down today and the entire inside of the box will get one last coat of paint.
CJs DC F150 codyj18 (DC) 107 03-26-2013 12:51 AM
f150 4 15s blowthrough tuned to 27Hz flexin thegreatestpenn Car Audio Videos 10 03-31-2011 11:13 AM
CJs DC Maxima codyj18 (DC) 25 02-10-2011 06:31 PM
Incriminator Audio lethal injection 15s or DC sound lab level 3 15s? SQLbeliever General Car Audio Discussion & Questions 36 01-21-2010 07:46 PM
