DC 5k and 12k clamp results - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 09-17-2011, 08:42 PM
Droppin' HZ Car Audio
0/11 sssss1596
Feedback Score: 26 reviews
Default DC 5k and 12k clamp results
The first test on the 5k was done by a friend that has the 5k wired at .5 running on a SMD 18.
Courtesy of kickass audio on SMD:
If someone is in the market for a DC Audio 5.0k amplifier then look here for the results i got out of my 5.0k.
I am running just one of these amps up to my single AA SMD 18" dual 1 ohm sub in a 5.5 cubic foot box tuned to 30Hz. The test was made with my sub wired in parallel to achieve a nominal impedance of .5 ohms and the battery voltage was 13.7v. The clamp results are as follows:
30Hz tone: 1454.583 watts at 1.41 ohms
35Hz tone: 2525.54 watts at 1.63 ohms
40Hz tone: 4061.64 watts at 1.37 ohms
45Hz tone: 5291.84 watts at .976 ohms
50Hz tone: 5161.32 watts at .971 ohms
55Hz tone: 5215.0 watts at .939 ohms
60Hz tone: 4778.4 watts at .912 ohms
Average impedance rise and wattage from 30-60Hz: 4096.76 watts at 1.173 ohms
Overall i am really satisfied with my DC 5.0k even though the low end tones have less power than my old amp (two Massive Audio DB8000's strapped at .5 ohms nominal) but the higher notes have a lot more power and the clarity of my 5.0k is amazing. With my DB8000's the clarity was alright but the bass was really punchy, with the 5.0k the bass seems to have a slower run off and a more even tone. Plus with this amp, it doesnt get warm at all when my engine is running, if i bump the amp at around half volume with the truck off for a total of 3 hours (i sit in the parking lot at class until my next night class starts) only one half of the amp is warm but its not enough to burn you like my old DB8000's.
Here are my results from the 12k.
I just got done clamping the 12k that I have running in the Dodge Caravan with 4 XL 18s and here are the results.
First the rated power chart.
14.4v
4 ohm 1200x2
2 ohm 2100x2
1 ohm 3400x2
.5ohm @ 12v 4200x2
.5ohm @ 14.4 5500x2
.5ohm @ 16v 6500x2
My Results- These tests were done 1 channel at a time and obtained identical numbers.
Tests were with voltage drop down to 12v.
Hz Amps Volts Watts Ohms Rise
30hz 44a 71v 3124x2 @ 1.61ohm 1.11ohm
35hz 40a 70v 2800x2 @ 1.75ohm 1.25ohm
40hz 40a 70v 2800x2 @ 1.75ohm 1.25ohm
45hz 41a 68v 2788x2 @ 1.65ohm 1.15ohm
50hz 42a 67v 2814x2 @ 1.59ohm 1.09ohm
Average- 2865.2w x2 @ 1.67ohm
This test was done with both channels wired at .5ohm
Overall I am extremely happy with the output of the 12k and most important the owner is happy. The van is playing music at 149-152.
Old 09-17-2011, 09:00 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
Any numbers on the voltage drop?
It seems very odd to me that even though impedance rise is similar that output is so varied from tone to tone. Care to explain that? Where were the SSF and LPF set?
And why is it called a "12k" if it's not a 12k? Lol.
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 09-17-2011, 09:01 PM
maxspl153's Avatar
0/11 ssssss134
not bad man , just put one in my little brothers truck (5K) . its on one lvl. 5 15 and he LOVES it . im sure hes going to be happy when i show him your thread
1995 GMC Sub-Burban
Powermaster 350A SPL alt
OEM H/O 150A alt
Deka group 31 AGM batts
SOUNDSTREAM XXX-15000D
(4) SOUNDSTREAM XXX 18'S
TEAM HEAVY HITTERZ
TEAM SOUNDSTREAM
Old 09-17-2011, 09:07 PM
0/11 sssss1596
14.4v
4 ohm 1200x2
2 ohm 2100x2
1 ohm 3400x2
.5ohm @ 12v 4200x2
.5ohm @ 14.4 5500x2
.5ohm @ 16v 6500x2
This just has to do with the variance in the amperage and voltage output at the frequencies measured. The ssf is at 25hz and the lpf is at 70hz.
The 12k will do 12000w at reactive .5ohm per channel at 16v. If you look at my clamped numbers per channel and see the big highlighted red ratings you will see that the amp is putting out true rated power at 12v.
Answers are in purple.
The 5k is a beast! I cant wait to get my 7.5 fired up.
Old 09-17-2011, 09:31 PM
0/11 sssss1286
so the 12k isnt a 12k unless ur running 16v
Old 09-17-2011, 09:35 PM
0/11 sssss1596
Here are the ratings.
Output Power (RMS) at 4 ohm 14.4V 1200W x 2 at 2 ohm 2100W x 2 at 1 ohm 3400W x 2 at 0.5 ohm 12V 4200W x 2 at 0.5 ohm 14.4V 5500W x 2 at 0.5 ohm 16V 6500W x 2
Considering that I am getting rated power with voltage drop to 12v, I would be comfortable saying that if you can get reactive .5 per channel or 1 ohm bridged, you would see the full 12k.
Old 09-17-2011, 09:41 PM
psychoacoustics's Avatar
Veteran Member
0/11 sssss3830
Feedback Score: 50 reviews
impedance rise is all across the frequency spectrum
although the nature of a woofer makes the highest impedance at the tuning hz making it put out the l least at that point
Old 09-17-2011, 09:42 PM
0/11 sssss1596
Funny thing is that the box is tuned to 29hz and I got the most power at 30hz.
Old 09-17-2011, 09:43 PM
Dunder Mifflin
0/11 sssss1897
I thought the 12k put up bigger numbers than that hmm?mmmmm !!!
jordan i want my subs
Old 09-17-2011, 09:44 PM
Veteran Member
0/11 sssss3830
usually thats how amps are rated but its actually 18v not 16
Crescendo Bass Clef series Clamp Results Crescendo Audio (Crescendo) 94 04-12-2012 05:28 PM
dc audio 12k??? lil_walbanger General Car Audio Discussion & Questions 187 02-25-2011 02:18 PM
Soundigital 12k johnperdeye Mono Amplifiers 5 10-23-2010 01:26 PM
single 12k tenbux1970 General Car Audio Discussion & Questions 30 08-13-2010 08:10 PM
Cs elite 12k loud avalanche General Car Audio Discussion & Questions 11 06-10-2010 08:16 AM
