DC 7.5k Clamp Results - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 09-22-2011, 02:51 PM
Droppin' HZ Car Audio
0/11 sssss1596
Feedback Score: 26 reviews
Default DC 7.5k Clamp Results
Here are the rated specs for the 7.5k.
Features Voltage 7.5kw
Output Power (RMS)
at 4 ohm 14.4V 2200W x 1
at 2 ohm 4400W x 1
at 1 ohm 7500W x 1
at 1 ohm 16V 8600W x 1
at 1 ohm 18V 9200W x 1
This test was done in my 2006 Ford F150. I am running 1 Mike Singer 350a alt independently from the stock electrical charging my 5 XS D1400 14v batteries at 16.4v
Voltage started at 16.4v.
Starting impedance is .67ohms
HZ----AMPS----VOLTS----WATTS----OHMS----Voltage Drop
30----.9----96.5----7806.85---1.19----15.2v
35----78.2----100.2---7835.64---1.28----15.2v
40----72.2----103.6---7479.92---1.43----14.1v
45----62.2----107.8---6705.16---1.73----14.7v
50----61.5----106.9---6574.35---1.74----14.7v
For those who were unhappy with the results I got when clamping the 12k in the mini van, I will be testing it in my truck at its full potential this weekend.
Old 09-22-2011, 03:06 PM
Ronmeister's Avatar
0/11 ssssss791
Awesome.
Honestly, I figured an increase in power output as you raised the frequency. Or do you attribute that to voltage dropping mostly?
Old 09-22-2011, 03:11 PM
0/11 sssss1596
Originally Posted by Ronmeister View Post
Awesome.
If you will read all of the results you will see that I have more rise on the higher frequencies. This is the cause of lower power output. I would still say that 6500w at damn near 2 ohms is pretty damn good.
Old 09-22-2011, 03:27 PM
profundus-sanus's Avatar
Veteran Member
0/11 sssss3026
kinda strange how the voltage dropped more on less power.
good numbers none the less.
you running the d1400's on the factory electrical?
Old 09-22-2011, 03:36 PM
0/11 sssss1596
Output Power (RMS)
at 2 ohm 4400W x 1
at 1 ohm 7500W x 1
Old 09-22-2011, 03:38 PM
0/11 sssss1596
http://www.youtube.com/watch?v=IGSEqFTuubA
http://www.youtube.com/watch?v=jlhQPrpPnwg
http://www.youtube.com/watch?v=05FsyOe7_LI
http://www.youtube.com/watch?v=p1fJj3cjjr4
http://www.youtube.com/watch?v=DskIcmSkNWg
Old 09-22-2011, 04:03 PM
RE_XXX's Avatar
0/11 sssss3182
I just clamped a 12k on 12 volts and got 6313 watts rising to 1.61 ohms.
10 batteries and 3 300 amp alts..starting voltage was around 14.9
Amps- Crossfire XS-8X
Wire- 6 runs Stinger
Old 09-22-2011, 04:16 PM
0/11 sssss1596
Is this supposed to be a serious post?
Old 09-22-2011, 04:23 PM
0/11 ssssss201
good numbers so guessing at 2 ohms it would be about 5500-6k watts which is way over rated, awesome!
Team Skar Audio
[SIZE=2]
'03 explorer 4.6l v8 (Legal [email protected] with 2 15" VVX on a BC2000 @.5)
New setup is underway!
Old 09-22-2011, 04:51 PM
RE_XXX's Avatar
0/11 sssss3182
Yup...... I can get the owner of the amp and get a vid of the clamp as well.
When we did it...with rise...my guess was between 6k-7k. I was dead on.
It could have been 1.9 ohms........ but it was somewhere in that area... gonna have to find out when i get home.
Crescendo Bass Clef series Clamp Results Crescendo Audio (Crescendo) 94 04-12-2012 06:28 PM
DC 5k and 12k clamp results codyj18 (DC) 22 09-18-2011 12:15 AM
Slamology results ESp Challenge Extreme Sound Production 14 06-20-2011 08:26 PM
PSI Results LyferXB9s (PSI Car Audio) 0 10-31-2010 09:31 AM
And the results are in..... toolmaker (Tool Maker) 20 08-31-2010 09:46 PM
