long round ports in small enclosures - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > Vendors > Direct Sound Solutions
Old 02-04-2015, 08:39 PM
0/11 ssssss285
Default long round ports in small enclosures
Below is an explanation on how DSS gets a 37.25 inch long round port in a box 24 inches deep without using elbows.
For this demonstration I'm using a 6 inch round port with a external diameter of 6.5 inches and a internal surface area of 28.25 inches.
Steps involved for calculating port.
1. How far away to make the end of the port form the back wall. (No it's not the diameter of the port). The port area is 28.25 inches so we need the area between the port end and back wall equal or a tad more than the port area. So surface area of a cylinder is...
area = (2pi x radius) x height
since we know the area...
28.25 = (6.28 x 3) x height
1.49= height (distance from port end and back wall)
Next a port extension is needed with an ID that will create a surface area of 28.25 inches between the port and the port extension. I use sketch-up as it takes much less time than doing it by hand. In this case a port extension with a 9 inch ID works well.
Finally the port extension length is calculated like any other slot port extension to create the needed 37.25 inches of total port length.
[IMG][/IMG]
The Following 2 Users Say Thank You to Quentin Jarrell For This Useful Post:
craiggus365 (02-21-2015), Todd Dupler (02-26-2015)
Old 02-04-2015, 08:43 PM
0/11 sssss1882
I'm laughing so hard right now. I don't know why I never saw it this way.
That being said I'm still trying to figure out slot ports. Where the corners are I have no idea how to calculate that in the length. So how would you figure this in a aero-slot port?
Old 02-04-2015, 08:57 PM
0/11 ssssss285
Port length is calculated by an imaginary line in the center of the width of the port. So just draw a line between the port walls and measure snaking around all the way to the end. Effective port length of a flared end varies depending on the rate of the flare but most of the time the point 1/2 the distance from the throat and mouth is used. So if you lay a flare on a table with the throat (the part that mounts to the port) on the table and measure it's "depth" and its 6 inches then the flare effectively adds three inches of length to the port.
Old 02-04-2015, 09:04 PM
0/11 sssss1882
Well I had planned on using some PVC and home making my port/flare. If I did it this way, let's say I start with 20". I flare about 1.5" lip on it to mount to my box. At this point its still 20"? Sorry I'm a visual learner. Imagining it isn't doing too well at the moment.
Old 02-05-2015, 06:02 AM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
I've actually used this concept before.
Ben trying to visualize an easier/cleaner way to make the transition between them.
Like the bottom half of this at the transition. If you can visualize that.
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 02-05-2015, 11:37 AM
0/11 ssssss416
Polk Audio came up with this concept in the mid 90's. There is actaully software available to model them as well. Google Polk power port and you can find some good resources, there are even some new commerical designs that utilize these as well as some DIY guides for making them.
Old 02-05-2015, 11:40 AM
0/11 sssssss32
So how do you calculate the displacement of the port??
Old 02-05-2015, 12:38 PM
0/11 ssssss285
The Power Port is not a port extension. It is a guide to couple the port to the baffle of the enclosure.
Old 02-05-2015, 12:39 PM
0/11 ssssss285
Volume = 3.14 x radius^2 x height.
Old 02-05-2015, 01:32 PM
0/11 sssssss32
So for example you picture. You would calculate the 6" displacement and the 9" displacement then add them together correct?
Question about round ports. dangeranger2008 General Car Audio Discussion & Questions 4 10-06-2012 02:58 PM
Please post pics of enclosures using 6" ports. jstjst General Car Audio Discussion & Questions 5 08-12-2011 05:13 PM
Who makes huge aero (round) ports? jt_buck General Car Audio Discussion & Questions 6 04-11-2011 06:09 AM
how you use round ports? MERQUE General Car Audio Discussion & Questions 2 04-05-2011 09:33 AM
3 round 10" ports jj53913 Enclosure Discussion & Design Construction Help 10 05-19-2009 10:27 PM
