glue joint failure - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > Vendors > Direct Sound Solutions
Old 02-23-2015, 12:21 PM
0/11 ssssss285
Default glue joint failure
I found out I had a bad batch of glue during quality control testing today. The glue looks fine but the inside of the beads are not curing . A different glue is being used so this wont be a problem but if you have received your 2015 drivers and find this issue send me an email and I will email a return label to recone your drivers or I can send out recones if you prefer to recone yourself.
What Local glue to use for Dustcap and Spider Re-Glue jkok7 General Car Audio Discussion & Questions 4 04-23-2014 12:32 PM
brand new PB 3XL cone to surround joint failing after 1 day! ca glue fix? snoopysnooper General Car Audio Discussion & Questions 5 01-06-2014 10:57 PM
sundown,splabs,ca glue,crossfire,autotek,dual inputs,ca glue stevew008 Car Audio Packages 5 11-11-2012 10:03 AM
sub glue joint ripped scfaust General Car Audio Discussion & Questions 7 03-01-2012 05:49 PM
Which Glue to Glue Sorround on Basket? Biggy General Car Audio Discussion & Questions 12 09-28-2010 05:47 AM
