2 12 dss ethos crescendo 5500 - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > Vendors > Direct Sound Solutions
Old 03-22-2015, 12:33 PM
0/11 sssss1117
Default 2 12 dss ethos crescendo 5500
Box 3.4cuft net with 72sq in port area tuned to 32hz.
electrical: 2 banks of the 2.7v 3000f capacitor. stock battery and alt 13.4v at full tilt.
amp: crescendo 5500
Im very impressed with the output and how it sounds. It takes every bit of the 5500 and gets down to the mids 20s hz and up to the 60hz+ and its brutal
https://www.youtube.com/watch?v=D3QHk-3fYiM&feature=youtu.be
Old 03-22-2015, 02:11 PM
0/11 sssss8594
Feedback Score: 55 reviews
i like the placement of that amp..need to put that grill back over it tho lol
Enclosures
Old 03-22-2015, 02:18 PM
0/11 ssssss247
I'm confused so this is a 16volt setup....or you can you the 2.7 caps in a 12volt 14volt and 16volt set too with out hurting anything
Old 03-22-2015, 02:54 PM
0/11 sssssss64
Do you have your amp in the side panel? Is that a tahoe?
Old 03-22-2015, 06:56 PM
0/11 sssss1117
Yea i wanted it out of sight. I was planning to make a grill. Ideas still floating still Got more work to do
Old 03-22-2015, 07:00 PM
0/11 sssss1117
Max charging voltage is 16v but you can use it in any voltage below 16v. Its not like 14v or 16v batteries where you need to have a higher charging voltage, and these can discharge to 0v.
Old 03-22-2015, 07:03 PM
0/11 sssss1117
98 ford explorer. usually they have a stock sub in this location, i had the pocket. It had some clips in the back to take out. i didnt think it will fit but it did. I mite put some led and a grill over with some neo magnet to hold the grill.
Few DSS Ethos Videos SWIFT Direct Sound Solutions 10 02-07-2015 09:17 AM
2 12 dss ethos box design SPL Addict General Car Audio Discussion & Questions 0 01-29-2015 01:55 PM
WTB DSS Ethos.. shriver187 Wanting to Buy (WTB) 2 01-13-2015 12:05 PM
12" DSS Ethos D2 spec134 Craigslist Deals 2 12-13-2014 07:37 PM
A few DSS Ethos vidoes (second try) SWIFT Car Audio Videos 15 12-06-2014 07:00 PM
