2 SA 10's in a single cab - Car Audio Classifieds!
Old 09-27-2011, 10:52 AM
0/11 sssss1046
Default 2 SA 10's in a single cab
I'm about to sell my Fi Bl 12 and was looking at the SA series subs. I've never done 10's, so i was looking at doing 2 10's (of course the box will be behind the seat). I can fit up to 2.8 cubes behind the seat, but looking at about 2.3 after port and sub displacement. My current setup does a 140.0 on the dash (at 40 hz), the box is tuned to 28 hz, and it smashes the lows like no other. I'm wanting to know what would be a good box volume and port area to run 2 10's in that would get me into that range, or hopefully higher. Also, i'll be running about 1300-1400 wrms to the pair. I know there are a lot of factors that go into how loud a setup is, so i would like to tune the box to 34 hz for a good overall sound. I've had my fun with the LOWWWWSS, but i'd like it to be a little better 45 hz and up.
Thank you.
Old 09-27-2011, 11:17 AM
0/11 sssss1046
I've modeled it in WinISD and it looks like 2.3 cubes with 30 sq in of port tuned to 34 hz will peak around 40 (theoretically). I can only fit up to 2.4 cubes so that's my volume limit. I've only modeled this though, and would like actual real world opinions on what would be best suited for me with the power i'm running.
Old 09-27-2011, 11:22 AM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
1-1.2 each would be fine. tuned to your liking. they'll dig low regardless
-Youtube Channel
Old 09-27-2011, 11:27 AM
0/11 sssss1046
OK. Also, what would be louder on the meter: port to the drivers side, or port to the passenger side?
Old 09-27-2011, 11:29 AM
0/11 sssss7816
Subs forward, aero out to pass side.
Atomic Loudspeakers
Audiotechnix
Old 09-27-2011, 11:33 AM
0/11 sssss1046
I was thinking just doing a square port, but i could fit a piece of 6"PVC (not enough room for a 6" aero if subs are behind passenger seat.) Would the aero do better on the meter?
I'm going over box deminsions, and would a 5" aero be ok, or would a 6" be recommended? ONly reason i'm asking is a 6 will make me crunched on space a little.
Old 09-27-2011, 11:35 AM
0/11 sssss7816
Aero will be louder.
Atomic Loudspeakers
Audiotechnix
Old 09-27-2011, 11:37 AM
0/11 sssss1046
But would i be ok running a 5" instead of a 6"?
Old 09-27-2011, 11:42 AM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
if you could find one.lol
-Youtube Channel
Old 09-27-2011, 11:43 AM
0/11 sssss7816
just bondo a smaller flare onto one to make it work
Atomic Loudspeakers
Audiotechnix
single cab s10 pokerchip11 General Car Audio Discussion & Questions 2 09-04-2011 07:32 PM
02 Silverado single cab 2 10's quaddropper Enclosure Discussion & Design Construction Help 0 08-10-2011 03:10 PM
2 sa-10s on 2k in a single cab Bobby32 General Car Audio Discussion & Questions 13 03-04-2011 09:31 PM
single cab bass? xkryptonitex General Car Audio Discussion & Questions 15 07-31-2010 11:11 PM
need help with box for single cab s 10 sonoma General Car Audio Discussion & Questions 1 07-28-2010 10:12 PM
