What kind of enclosure is this? - Car Audio Classifieds!
Old 09-29-2011, 11:25 PM
Matt3824's Avatar
0/11 sssss3754
Default What kind of enclosure is this?
When I was at world finals this past weekend, I seen the subs mounted on a wall, but the whole side was open to where you could see the side of the sub and pretty much walk inside the enclosure. It didn't even looked tuned to any degree, it just looked like the sound reverbed around the box into the cab.
Who knows what I'm talking about?
Old 09-29-2011, 11:34 PM
Dbmonster's Avatar
0/11 sssss1217
sounds like a typical ported wall to me, I'm guessing the baffle was super thick? the thickness of the baffle is the port length.
WARNING: Due to high sound pressure levels, all passengers are encouraged to remove any and all tight or restrictive clothing such as bras, thongs, etc. before entering this vehicle.
Old 09-29-2011, 11:36 PM
Matt3824's Avatar
0/11 sssss3754
Didnt even have a port though. The port height would have been the height of the cab and width would be the edge of the baffle to the other side of the car.
Old 09-29-2011, 11:37 PM
0/11 sssss7816
Jerry Fender Mod 2-4000 163 db Run -- ATOMIC - YouTube
Atomic Loudspeakers
Audiotechnix
Old 09-29-2011, 11:38 PM
Pieper's Avatar
Winston Churchill > You
0/11 sssss9716
Feedback Score: 84 reviews
Still a port.
Old 09-29-2011, 11:45 PM
Dbmonster's Avatar
0/11 sssss1217
Originally Posted by pieper88 View Post
Still a port.
what he said
the roof, floor, and side of the car act as 3 walls of the port and the edge of the baffle is the 4th wall. the thickness of the baffle is the port length, its no different then a slot ported box that uses the top, side, and bottom of the box as port walls, just on a bigger scale.
Old 09-29-2011, 11:59 PM
grocerygetter's Avatar
New build coming soon?
0/11 ssssss583
2 inches of port area tuned to 46 million hz ftw!
Old 09-30-2011, 07:07 PM
Matt3824's Avatar
0/11 sssss3754
So umm tuning?
Old 09-30-2011, 07:53 PM
Dbmonster's Avatar
0/11 sssss1217
So umm tuning?
Are you asking what it's tuned to?
Old 09-30-2011, 07:59 PM
grimreper912003's Avatar
Hook me up with dat JL
0/11 sssss6190
Was it a burp box? usually with the volume they run port length is very short.
what kind? FOGEL A.KA.MCLOVIN Enclosure Discussion & Design Construction Help 3 10-06-2010 09:31 PM
WTB: ported 12" enclosure of some kind snoopysnooper Wanting to Buy (WTB) 10 10-06-2009 09:01 PM
What kind of relationship would you rather be in? BarbieBs_Mindbox Powder Room 43 03-08-2009 12:13 AM
Looking for an equalizer of some kind. Let me see what you got tahoebrotha Wanting to Buy (WTB) 0 11-24-2008 06:52 PM
