REXXX15 box question(s) - Car Audio Classifieds!
Old 05-10-2009, 02:43 PM
0/11 ssssss165
Default REXXX15 box question(s)
OK, before i decided 100% if i ma ditching the XXX or not i am wanting to try it out in a new box. Right now i am running a factory spec box 4ft^3 @ 33hz and it just doesn't impress me. So i am open to suggestions here...
area to work with
height: 16.5"
depth: 24"
width: 36"
now the pretty much seals the trunk area from the cab so i figure I should most likely port through the rear deck with the sub facing the rear. I am just wondering what the best results have been as far as box size and tuning frequency. I keep trying to compare this setup to my HDC315 in a 4.5ft^3 @ 40hz but bottom line is that it just don't compare... I keep hearing they need a pretty decent size box and that the 33hz is a little on the low side but i figure i would toss this out there and see what people have to say...
Old 05-10-2009, 02:51 PM
No, I'm not dead
0/11 sssss8128
They need a big box, you've got a bit under 8 cu ft after allowing for panel thickness. That's pretty good size but after port and sub displacement it's going to be around 6 cu ft. You'll want to tune lower than 40hz, I'd try to get down around 25hz if you can work in the port displacement.
Old 05-10-2009, 02:57 PM
thedukey42's Avatar
0/11 ssssss724
Actually, what year xxx do you have?
Also, if you're going to fire through the deck, front fire the sub and seal it off from the trunk.
Old 05-12-2009, 07:20 PM
0/11 ssssss165
it's an '08 XXX running on a Memphis 4kw
Also i am doing an external port so that won't take any space from the box itself...
Have question, Need help! Bigboiii General Car Audio Discussion & Questions 13 03-22-2009 09:52 PM
I've got a question... again madmat Announcements - Suggestions - Feedback - Support 6 03-20-2009 11:54 AM
H/U question? mcdstvn General Car Audio Discussion & Questions 4 03-17-2009 09:19 AM
GIF question caps Technology & Computer 2 02-17-2009 09:44 PM
DD Question worstenemy453 General Car Audio Discussion & Questions 30 01-12-2009 08:42 PM
