Tuning a Clamshell???? - Car Audio Classifieds!
Old 10-03-2011, 07:55 PM
0/11 sssssss20
Default Tuning a Clamshell????
My Goal is to put 12 10 inch subs into a Clamshell wall in a Ford Focus ...I have approx 24-26 cubic feet to use for these subs
My question is how do I tune a Ported Clamshell?
Old 10-03-2011, 08:12 PM
Novicaine's Avatar
CACO Late Night Crew
0/11 sssss6135
In the real world everything comes out sort of different then planned. You can try and tune it precise but it may come out different. I use my woofer tester to get an idea where my loadings are and what kind of response i will have...
Old 10-03-2011, 09:01 PM
surreal's Avatar
0/11 sssss2489
Subs will be loaded differently.. though you can do it.
At this point, its really just a ported box with subs mounted in/near the end of the mouth. Best thing you can do really is design it as such. Any further effort will be negated by the huge effects a vehicle will have playing that in such a small enclosed space.
Old 10-04-2011, 11:18 AM
0/11 sssssss20
What could I do to improve the overall design ? I know fring the front wall to more of an angle will help with loading and bring rear more facing outward
Old 10-04-2011, 11:29 AM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
Are you looking for door open/window down demoing or sealed up loud? That plays a big roll really. If designed for sealed it will fall flat with the windows open and possibly unload something terrible. But if you go loud windows down then you lose sealed up.
What kind of tunning are you planning and how much power?
Old 10-04-2011, 11:32 AM
0/11 sssssss20
it will be windows down demo ...probably 3k rms right now 36hz tuning
Old 10-04-2011, 11:37 AM
Ja Marcus
0/11 sssss6975
WIndows down I wouldnt go with as much port area. Start big but plan to shrink it down. I currently run about 150 sqin of port for mine with a tunning in the low/mid 20's with a PB to about 55hz -3db.
I would try to angle the front subs more inward. That should help re-enforce the wave as it exits the "mouth".
Old 10-04-2011, 11:41 AM
0/11 sssssss20
OK cool, I will try that when I get home ... figure maybe a 80 degree angle for the front baffles and got to figure out the " inner baffle" angle ... think if built properly this could get loud?
Old 10-04-2011, 12:45 PM
Ja Marcus
0/11 sssss6975
How much power do you intend to run?
Old 10-04-2011, 02:43 PM
0/11 ssssss413
As I said on ROE, you'd be a lot better off if all the woofers were on the same plane. You've got the room to do it.
clamshell kingtidis Enclosure Discussion & Design Construction Help 117 07-22-2011 05:29 PM
clamshell design Ryan Shaw General Car Audio Discussion & Questions 7 07-22-2011 12:26 AM
clamshell help bmpn160 Enclosure Discussion & Design Construction Help 0 11-28-2010 08:33 PM
Clamshell? SCHMITTY Enclosure Discussion & Design Construction Help 7 10-14-2009 01:49 AM
clamshell questions kurrupt General Car Audio Discussion & Questions 118 06-30-2009 12:13 PM
