I need help with 4 10"s - Car Audio Classifieds!
Old 10-06-2011, 02:19 AM
Unleash The Beast
0/11 ssssss245
Default I need help with 4 10"s
I have 4 10" Sundown SAs on the way DVC 2 ohm (so I can wire to 1 Ohm) I want to be able to have a daily setup and a spl setup. I was thinking aero ports are the best way to do this. Possibly 30 hz for daily, and about 40hz for spl, using some sort of plug. I have read hours of threads and still cannot find all the info Im looking for. I want to build my first ported box, but I'll need a coach if you will...
Roughly the space i have is:
L 25 1/2"
W 32" INCHES
H 15 1/4"
My max box size is 7.201 cubic feet. Not counting subs or wood ect. Take me for a beginner, as that I am at box building. Everything else I'm fine with.
If possibly someone is nearby where we could do this together I am willing to pay. I want the absolute LOUDEST I can get. These are going in a trunk of my 2008 Lancer GTS. Check my signature for my current setup.
Things I think are right: Rounded corners/edges, painted box, wood glue, and wood screws, possibly rods, possibly 45 degree corners inside box (I've heard sometimes this could decrease DBs), Resin or not I'm not sure(remember this is for daily and spl I dont know if resin will change quality), to flush mount the woofers or not depending on the design.
I have several box ideas I will try to get up here in image so you can tell me what you think of the ideas. I have cutout the middle of the backseat, to have the box port through the back seat (I think this would increase my DB, that is why I choose to do this).
ADDED Pics:
VERY rough images, just so you can see what I was thinking about. Trying to avoid trunk rattle if possible.
Subs forward port forward almost a box inside a box.
Subs firing down ported out the front and cone pressure out the front if possible too
Seen this by Skip01 his got VERY loud I hope I can do the same
Check out my ride
Did I help you out?
Don't forget to hit thanks ------->
Old 10-06-2011, 02:35 AM
mads10bass's Avatar
NOT LOUDER THAN YOU :(
0/11 sssss7335
Feedback Score: 36 reviews
do you have 6x9s in rear deck? if so i would remove them and locate new better speakers in your frontstage and maybe even rear doors to make up for them. this will allow even more air to get into the cabin. I would personally do sub up port to the side leaving room for air to make it around and in front of the box to get into the cabin via ski pass and 6x9 holes. aero ports will help save space and give you more space to work with. 2 6" is what i would do in your situation
WOW
Old 10-06-2011, 03:45 AM
Unleash The Beast
0/11 ssssss245
No I have no 6x9 in rear deck at all. So cutting a port, or hole through the rear deck would be best to allow the ported air to escape? I was trying to avoid having port and subs in the trunk really. To avoid trunk rattle, which I barley have any the way its set up now, and i do want to get loud though so whatever would be best i guess. im posting pics now in original thread.
Check out my ride
Did I help you out?
Old 10-06-2011, 02:07 PM
Unleash The Beast
0/11 ssssss245
bump.
Check out my ride
Did I help you out?
Old 10-06-2011, 02:10 PM
grimreper912003's Avatar
Hook me up with dat JL
0/11 sssss6190
Im sorry if I missed this but, Why not build a 4th order ported directly into the cabin and sealed off. Then no trunk rattle plus it should be louder. Not 100% sure but in theory.
Old 10-06-2011, 07:18 PM
supadave's Avatar
0/11 ssssss203
grim is on to something. but like skips design it will work. on a gp3k an 4 fosgate p3's i did a 147.7 an that wasn't even tuned llike breann's was in that saturn in skips video.
far as truck rattle goes get you audiotex or some kinda deadner do at least 2 layers on the trunk that should keep rattle down but if you don't want rattle you need to do all 4 tens forward an port an seal it off it can be done if you can go 40 wide.
Old 10-06-2011, 10:13 PM
Unleash The Beast
0/11 ssssss245
I thought you shouldn't do lower tuned 4th orders? Im trying to do 30 and 40 hz tuned at the box.
Check out my ride
Did I help you out?
Old 10-06-2011, 10:14 PM
Unleash The Beast
0/11 ssssss245
What do you guys think about the second picture I put up there? ive never seen anyone box like that before but I thought it MIGHT be a good setup.
Check out my ride
Did I help you out?
Old 10-07-2011, 09:27 AM
Unleash The Beast
0/11 ssssss245
bump.
Check out my ride
Did I help you out?
Old 10-07-2011, 09:55 AM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
Of those You posted I'd do skips. The 2nd one Looks to be downfiring. In that case, I say no. The waves comeing off the tob of the subs would be wasted
-Youtube Channel
2-15" Ti Baskets, 10" spider landing, 3" & 4" coil, New Custom Colors and Never Used! zeuslicious Speaker Accessories & Parts 18 11-06-2011 06:53 PM
FS: 2-15" Ti Baskets, 10" spider landing, 3" & 4" coil, Custom color and Never Used!! zeuslicious Speaker Accessories & Parts 22 08-04-2011 12:08 AM
[SOLD]2 Digital Designs 9510 "F"'s with G Parts CF Dual 1.4 aluminum "Z" coils. JustinWhitty 10" Subwoofers 15 07-01-2011 07:13 AM
Dom takes the 6alt hoe to "autoparts" stores for "testing" 98HOEONSIXEZ Car Audio Videos 174 07-07-2010 10:15 PM
Mid/Tweeter "cups"/"covers"/"enclosure"/"etc"??? oxsign General Car Audio Discussion & Questions 11 04-21-2010 04:29 PM
