Check my Port specs before i build? - Car Audio Classifieds!
Old 10-09-2011, 11:11 AM
Kidthump's Avatar
Awaiting Confirmation
0/11 ssssss346
Default Check my Port specs before i build?
Alright, I'm looking around 7 cubes @ 30hz after displacement from subs and port.
My outer dimensions are 41w, 18.25h, 24d.
Got two port dimensions, 5 inches wide, 16.75 tall, and 17.5 long.
And another is 4 wide, 16.75 tall, and 20 long. Which will give me my desired tuning?
Or if both are wrong can someone help me?
01 Jeep Grand Cherokee Laredo 4x4
JVC KD-S26-1/0 Gauge-Audiopipe 1002
2 Obsidian 15's-Audiopipe 1500d
7 Cubes, 30hz
Old 10-09-2011, 11:19 AM
oslouie's Avatar
0/11 sssss5073
Feedback Score: 69 reviews
If you go with the first port, it will be 7.46 cubes tuned to 34.75hz and you'll have 11.23 sq in of port per cube.
Using the second port will be 7.49 cubes tuned to 30.01hz and 8.95 sq in of port per cube.
You need to figure the displacement of your subs before doing all this calculating though because it will change airspace and tuning.
Old 10-09-2011, 11:23 AM
Kidthump's Avatar
0/11 ssssss346
Is their anyway i can do 30hz with more port area? because 8.95 per cube sounds like too little to me.
2 OA's should take up 0.38 cubes
7 Cubes, 30hz
Old 10-09-2011, 11:25 AM
oslouie's Avatar
0/11 sssss5073
If the box is for the OA15's in your sig, after sub displacement, the first box is:
7.08 cubes tuned to 35.67 with 11.83 sq in of port per cube
The second one after sub displacement will be:
7.11 cubes tuned to 30.80 with 9.42 sq in of port per cube
Old 10-09-2011, 11:27 AM
Kidthump's Avatar
0/11 ssssss346
Do you think the 2nd port will have enough port area?
OA only recommended 30 sq per.
7 Cubes, 30hz
Old 10-09-2011, 11:29 AM
oslouie's Avatar
0/11 sssss5073
I think you should be fine. Why tune so low? These are to be tuned to 32hz is what Nick said.
Old 10-09-2011, 11:33 AM
Kidthump's Avatar
0/11 ssssss346
Tryin to hit lows hard lol. Say's 28-32 on their site.
After displacements this box is almost 31hz. will one hz change much? I'll take all opinions man.
7 Cubes, 30hz
Old 10-09-2011, 11:36 AM
oslouie's Avatar
0/11 sssss5073
Maybe. I couldn't tell you that but here's my thread about my box:
How does this look? - Car Audio Classifieds
If you go 22" instead of 20" long, then you'll be at 7 cubes exactly, tuned to 29.94 and 9.57 sq in of port.
The Following User Says Thank You to oslouie For This Useful Post:
Kidthump (10-09-2011)
Old 10-09-2011, 11:43 AM
Kidthump's Avatar
0/11 ssssss346
Thanks for all the help man!
7 Cubes, 30hz
Old 10-09-2011, 11:46 AM
Kidthump's Avatar
0/11 ssssss346
Wait, 22 deep port. the whole box is 24. Would it be okay having like 1.25 inches between back and port?
7 Cubes, 30hz
New build check it out luises14 General Car Audio Discussion & Questions 7 10-07-2011 01:26 PM
Sq in of port is wrong?, XFL specs? Racerkid15 General Car Audio Discussion & Questions 6 09-20-2011 06:57 AM
Drek75633's 3) 18s in a mustang build! Lots of batts and neo subs. Come check it out. cthedinger Build Logs 111 12-10-2010 06:36 PM
double check these specs plz? B sparks Enclosure Discussion & Design Construction Help 0 01-26-2010 08:57 PM
Need help finding specs to build box slimjig Box Requests 10 11-14-2008 01:05 PM
