BP design request, ASAP have $ to PP - Car Audio Classifieds!
Old 10-09-2011, 01:20 PM
kmanian1's Avatar
mine>yours
0/11 sssss2130
Default BP design request, ASAP have $ to PP
Sub: 1 Phoenix Gold Ti210d4
Input power: 750w
Size Constraints: 32"w X 15"t X 20"d (bottom) 16" (top)*the dept is a measurement I want to keep if possible.
Additional requirements: 4th or 6th order is fine, useable freq below 35 hz to above 80hz. Solid bass reinforcement is key, fairly flat between 40 and 70hz. The box will be located in the trunk of an M5 with the port(s) entering the cabin through the rear deck which is at approximately 20" from the trunk floor.
Specs can be found on this link http://www.phoenixgold.com/images/pd...fer_manual.pdf
I will PP $ for a complete design including cut sheets. No offence, but if you don't consider yourself a enclosure design guru, please save both of us some time.
Old 10-09-2011, 08:26 PM
kmanian1's Avatar
mine>yours
0/11 sssss2130
so are there any BP designers out there?
Old 10-09-2011, 08:54 PM
surreal's Avatar
0/11 sssss2489
~30->80hz is going to be somewhat hard to achieve. Going to be a big loss in output for that large of a passband especially in that type of a setup.
Old 10-09-2011, 09:11 PM
kmanian1's Avatar
mine>yours
0/11 sssss2130
tkx, I gave my wish list now we will see what can be done
Old 10-09-2011, 09:19 PM
Novicaine's Avatar
CACO Late Night Crew
0/11 sssss6135
80hz is sort of high even though it's kind of a standard....Maybe you should re consider for a lower upper cutoff? 50-60hz? A sealed box with alot of cone would be loud, sound very good, and be flat all the way through.
Old 10-09-2011, 09:27 PM
kmanian1's Avatar
mine>yours
0/11 sssss2130
I have a reason for going BP, so other styles are out. If it hs to be a narrower band it will just have to be. I am hoping that a guru will work som magic and get a pretty wide band that I can tweek with an eq to flatten out if necessary,
I only have room for 5" mids so a higher cut off is pretty necessary, not saying 70hz wouldn't be ok, but I want to see what can be done.
Old 10-09-2011, 09:41 PM
surreal's Avatar
0/11 sssss2489
Is output not such a major concern?
You could go with a higher tuned 4th order.. 50-55hz or so at least and it should be acceptable down to 35/30ish given cabin gain you will get and play pretty flat. This is given you arent overpowering the speaker.
Your upper end will most likely still cut off ~70hz or so depending. Audible range there is very weird anyway but youll have sound.
Old 10-09-2011, 09:47 PM
kmanian1's Avatar
mine>yours
0/11 sssss2130
output is secondary, quality bottomend reinforcement is the goal.
the sub is rated at 600rms 1200peak (yadda, yadda, yadda) the amp is 550 @ 2ohms.
I just don't want 40hz and lower to suck a ss
Box request for Caw108 NEED ASAP Caw108 Box Requests 0 03-23-2011 11:28 AM
6th Order Design needing Help ASAP CROSSFIRE tC Enclosure Discussion & Design Construction Help 4 08-23-2010 09:01 PM
J31Rob has $ for box design ASAP!!! J31Rob Box Requests 4 06-12-2010 01:35 PM
i need a box design asap!! babaganoush123 Box Requests 1 10-26-2009 01:20 AM
3 15" TC3000's DESIGN NEEDED ASAP jdubbau Box Requests 1 09-29-2009 02:02 PM
