How Do you seal off a wall enclosure ? - Car Audio Classifieds!
Old 10-10-2011, 12:50 PM
0/11 ssssss446
Default How Do you seal off a wall enclosure ?
needing to no how to seal up a wall enclosure ? wat materials / products do i use? i dont wnt anything crazy just a nice clean seal proly wrap itwith carpet... would i just glue it to the enclosure or use like a masonite board and maybe bondo areas that dont cover with board... all input is appreciated..need to no how and materials to use ,,, thanks
Old 10-10-2011, 12:55 PM
0/11 ssssss884
depends how your wall is set up any pics?
Old 10-10-2011, 01:03 PM
0/11 ssssss446
no pics just gonna be 2- 15s in 4th order wall ... just try n to get everything together ill proly have TBH Enclosures (Surreal) Design me something wen hes not so busy.. he just designed a box for 2- solo X 18s in a 4th order and its SOOOOOOO NASTY my friend actually did the build 918 Customs ....
Old 10-10-2011, 01:38 PM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
When you say "seal" do you mean seal the front cabin from the back cabin air tight? Or "seal" as in make a nice trim panel to "look" sealed?
Cause there is no non-messy way of sealing the cabin tight.
Old 10-10-2011, 01:42 PM
jcp0420's Avatar
0/11 sssss2117
Yup this guy is correct. Foam is a common way of sealing it up then trim panels to make it look legit.
Old 10-10-2011, 01:55 PM
SPLpizzaguy's Avatar
Humbled by CACO
0/11 sssss3110
Feedback Score: 57 reviews
great stuff... ima expando foam giant.
4 sa10s
Taramps 8k
4 American Bass VFL 6.5s
Ohio Generator 305 amp alt
4 Vifa Tweets.
Old 10-10-2011, 02:02 PM
tacomaguy1's Avatar
0/11 sssss4401
depending on how much room is around the edges you can do it like this...
glue a piece of 3/4 mdf 3/4" back off the edge, around the outside of the box. So you can make the trim panels and have something to screw them to.
If that makes sense
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
Old 10-10-2011, 04:35 PM
0/11 ssssss446
yes id like to completely seal it off... and then make some sort of trim panel .. wat is this foam u guys speak of ? and were do i get it from ... the subs will be in the enclosure being its a 4th order wall .. so can i just use like a piece of masionite and screw to the foam area once it hardens up ? or any other suggestions would be great this is my 1st attempt to completely seal off a wall...
Old 10-10-2011, 04:49 PM
0/11 ssssss759
being a 4th order wall if u go the route of completely sealing it up its going to be a B**** to replace the subs if need be ... is it 100% necessary to seal it instead of just panel it off ? ..
Josh Wahlie's Avatar
< Pic from my build log!
0/11 sssss3196
Here is a link to how I did it. It starts on the page with the link below and you'll have to go through some pages to see the rest of the pictures, but the way I did it it should be able to go back to stock without damaging any interior and it is completely sealed off.
Team Concepts Wahlie 4 15" LVL4XL build
Custom Box Builder (Ships all over the USA)
Shok Industries Dealer
Tags
18s, bass, groundpounder, loud, wall
Removing Peel n Seal Legendary754 Sound Deadening & Fabrication 34 10-16-2011 07:51 AM
Wall enclosure plans. jinxd General Car Audio Discussion & Questions 4 09-03-2011 07:15 PM
best way to seal a trunk? onelivinlarge General Car Audio Discussion & Questions 6 11-03-2010 12:05 PM
To seal or not to seal? Fatboy501 General Car Audio Discussion & Questions 32 11-02-2010 08:14 PM
Is a sub gasket vital to seal the sub or can i get away without? Novicaine General Car Audio Discussion & Questions 14 07-01-2010 06:50 PM
