Single???Double???space???tuning??? - Car Audio Classifieds!
Old 10-10-2011, 01:25 PM
0/11 sssssss63
Default Single???Double???space???tuning???
plan on gettin 2 AQ HDC3s 12s this month
35x21.75x14 is outside with a double baff front =4.73cf
i was wondering which would be the best way to go single port/chamber or double port/chamber and what tuning should i use
MIX i know what ur gonna say lol use ur design ... i checked it wont fit
Old 10-10-2011, 01:43 PM
98Expo's Avatar
0/11 sssss1929
Feedback Score: 23 reviews
i dont know if 2 chambers would b louder, I had 2 hdc3 12's off a sundown 3500 with subs up and one center slot port to the back and it was crazy, then I built it with subs up and 2 slot ports firing to the rear and could tell no difference. Both were close to the same size you mentioned
2 FI bl 18's walled in 2012 scion xb
Old 10-10-2011, 01:55 PM
Zooook's Avatar
1337 M3mb3r
0/11 sssss3991
Feedback Score: 31 reviews
That box would be 4.7cf before any displacement..Subs are .17-.19cf each so around 4.3cf then you need port...box seems to small unless you used aeroports. You'd probably wanna use 3 4" aeros which would probably take up around .3-4cf...be kinda small still but it may work for two 12" hdc3's...I was suggested 4.5-5cf net for hdc3's...so I went in the middle 4.7cf after all displacement.
ALL FOR SALE ALL FOR SALE PM ME FOR PRICES
2003 BMW 330I
2x12" AB HD/W DC XL recones
Old 10-10-2011, 02:19 PM
0/11 sssssss63
to small FAIl i might be able to squeeze a couple more inches out of it in depth im jus not sure if ill be able to get it in my trunk lol but i appreciate ya help
Old 10-11-2011, 10:26 PM
0/11 sssssss63
Could i pull off a single baff? I might have to we came up with single baff and 35x23.5x14 it cumes out to 4.5 but its single baffed tuning is 35hz
Old 10-12-2011, 02:49 AM
98Expo's Avatar
0/11 sssss1929
the box i ran was 38" w x 14" h x 23.5" deep, with double baffle on top and port back. I think it was 4.25 cubes after displacements @ 36hz and it was perfect for me
Tags
audioque, box, hdc3 12
Space saving install. Single 10 ~1000w Phreaxer General Car Audio Discussion & Questions 0 08-29-2011 09:29 AM
Lincoln LS single and double din mounting kits SPY Wiring, Electrical & Other Installation Equipment 4 06-05-2011 10:37 AM
Build log for Juan651, Single 18 NS, double kerf....3kw iamamp3pimp Build Logs 4 03-24-2011 02:42 PM
SA-8 single vs. double spider pack testing (with fancy graphs!) tommyk90 (Sundown Audio) 18 08-27-2010 03:30 PM
Double checking my tuning aturcotte127317 Enclosure Discussion & Design Construction Help 4 03-05-2009 07:32 AM
