1 6" Aeroport for 1 18? - Car Audio Classifieds!
Old 10-11-2011, 09:07 AM
kz650's Avatar
0/11 sssssss95
Default 1 6" Aeroport for 1 18?
Would 1 6" aeroport for a PSI Platform 2 18" in an enclosure that is 4.55 cubes net tuned to 32 hz work? The sub will be up with the port towards the back firing towards the drivers side wall in the trunk of a 2005 corolla. I will either be using a PSP port or a port from derrick.
Old 10-11-2011, 09:10 AM
kz650's Avatar
0/11 sssssss95
Oh and the amp would be an aq2200d.
1loudyukonxl's Avatar
0/11 sssss1569
Kinda small but if your looking for just lows it will work
4 custom ia warden 18s d2
box 16.1 cubes 207 inches port 34.6
8 saz2500ds strapped at 1 ohm
21 kinetik 16v 3 dr44 alts 11 runs 1/0
high amps sax 200.4 sax 125.2
4 6.5 beyma g40s 4 10 o2 pros
tweets oldschool earthquake aka screamers
current spl on term lab 158.1 db at 37 htz no wall
Old 10-11-2011, 09:11 AM
0/11 sssss1569
I would use a 8 inch port
Old 10-11-2011, 09:13 AM
kz650's Avatar
0/11 sssssss95
Well if I went with an 8" I would be down to 4.14 cubic ft net tuned to 35 hz same configuration sub up port to the driver side. I'm mainly wanting to slam the lows because my car peaks around 36-38 hz and I generally like to listen to music that gets into the mid to low 20's and into the upper 30's.
Old 10-11-2011, 09:19 AM
0/11 sssss1569
Then do the single 6
Old 10-11-2011, 09:23 AM
kz650's Avatar
0/11 sssssss95
Thanks I appreciate the input!
Old 10-15-2011, 12:20 PM
kz650's Avatar
0/11 sssssss95
Any other input from anyone?
Old 10-15-2011, 12:23 PM
DonH's Avatar
0/11 sssss6645
Feedback Score: 30 reviews
first off, the box is to small for that 18, second a single 6" aero for a single high powered 18 is not enough port area. a single 8" would be fine
SHABAM
Old 10-15-2011, 12:26 PM
kz650's Avatar
0/11 sssssss95
Hmm....
WTB: 3 or 4" Aeroport jmilch Wanting to Buy (WTB) 2 08-17-2011 08:39 AM
WTB: 6" aeroport doug118 Wanting to Buy (WTB) 2 08-08-2011 10:09 PM
WTB: 1 - 6" Aeroport Oldbass38 Wanting to Buy (WTB) 7 08-04-2011 12:28 PM
6" aeroport jdmferio13 Wanting to Buy (WTB) 1 02-26-2011 01:04 PM
WTB:6" aeroport splvictim20 Wanting to Buy (WTB) 5 02-14-2010 12:31 PM
