HELP W BOX DESIGN FOR 2-15" HDC3's n TRUCK - Car Audio Classifieds!
Old 10-12-2011, 01:33 PM
0/11 ssssss316
Default HELP W BOX DESIGN FOR 2-15" HDC3's n TRUCK
I have a 2002 Nissan Frontier truck that i'll be putting in 2,15" AQ HDC3's in.The measurment's in the back are,48"w x 21"h x 19"d.That's right below the window and not past the piller's.Yes,I will be competing in MECA this year so it need's to play music,but be loud as possible.Any suggestion's?Type of material's,size,port size and depth,what to use for inside the box?Any advice or help would be greatly appreciated,thanx.
Old 10-12-2011, 01:46 PM
0/11 ssssss759
tbh enclosures in vendor section but u may have to wait in line hes a lil backed up last i checked but well worth the wait...
Old 10-12-2011, 01:58 PM
0/11 ssssss316
thanx will try
Old 10-16-2011, 01:38 AM
supadave's Avatar
0/11 ssssss203
you could build your box as big as the measurements you just gave an put a slot port across the back as wide as the box an play with the port, playing in orgs or comps you need a term an use that to tune your box out to whatever freq you want.
Old 10-16-2011, 01:52 PM
0/11 ssssss316
why port accross back
Old 10-16-2011, 04:40 PM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
ive heard subs forward port on drivers side is loudest for numbers. But if you want daily then have the port on the pass side
Old 10-17-2011, 04:44 AM
disturb3d_pri3st's Avatar
0/11 ssssss267
I did quite a few setups in my tundra and found that subs firing up and port up on passenger side was pretty damn loud, also subwoofers up and port on bottom of box firing towards my driver side door was loud as well.. if you have the time build a very solid box or two and decide how you like it.. every vehicle is different, from experience though I do say the port on passenger side subs up was my favorite.
Old 10-17-2011, 10:49 PM
0/11 ssssss316
k,u think birch is better than mdf
Old 10-17-2011, 10:52 PM
davidrforbus's Avatar
0/11 sssss6030
Feedback Score: 59 reviews
Birch is stronger and lighter than mdf is but is also more expensive, I'd do birch if it'll be a comp build.
Old 11-25-2011, 03:33 PM
0/11 sssss1406
birch over mdf any day, and requires a lil less bracing wich means more cubes
2 15"HDC3's box build for truck jessdabest77 General Car Audio Discussion & Questions 8 06-23-2011 07:24 AM
single 9515 in a supercrew truck, need opinions on box design bigdhenderson Enclosure Discussion & Design Construction Help 85 03-08-2011 11:56 PM
HELP! Box Design for 2 15" HDC3's nda03vic General Car Audio Discussion & Questions 10 11-12-2010 10:49 AM
Double kerf 18" truck box FLAstrongman Build Logs 8 08-31-2010 06:26 PM
Truck Box Design for Audiopulse Axis 12'' Bobby32 Enclosure Discussion & Design Construction Help 2 06-20-2010 09:11 PM
