fitting in a wall - Car Audio Classifieds!
Old 10-14-2011, 05:30 PM
Russellabt's Avatar
0/11 ssssss322
Default fitting in a wall
I have a Kia optima and im planning on walling it off with 4 obsidian 15s, would be a big box so I think I would need to build it inside the car, would it be smart to build the shell if the box like back, sides top/ bottom tehen leave the front for tuning? I ask this because I plan to have some one design the tuning, just have akward dor measurments, plain and simple I want to just build the max box and figure out tuning later
Old 10-14-2011, 06:00 PM
If you're going to start with a shell, just make it as big as possible. You can always add to the inside of the box to change the volume. I would to a removable port as well.
If you aren't doing a shell then I would just build the box outside of the car to spec, slide it in, and then attach the cover panels to seal it off.
Old 10-15-2011, 02:19 AM
98Expo's Avatar
0/11 sssss1929
Feedback Score: 23 reviews
if you are building inside the car, invest in a Pocket Hole Jig, I just built wall inside my expedition, and without that tool, It would have been alot harder. That jig made working from the inside alot, I mean alot easier. I would just build a shell like you are talking about as big as possible, then you can adjust the front for port and tuning.
2 FI bl 18's walled in 2012 scion xb
Header Reducers w/ 02 fitting stills Miscellaneous Stuff For Sale 3 04-16-2011 07:52 PM
civic hatchback-to wall or not to wall? Dbmonster Enclosure Discussion & Design Construction Help 2 12-14-2010 02:12 PM
fitting a d3100 aviator08 General Car Audio Discussion & Questions 2 06-25-2010 06:34 PM
Battery fitting aviator08 General Car Audio Discussion & Questions 0 12-18-2009 02:02 PM
