Aero port distance from inside box question - Car Audio Classifieds!
Old 10-15-2011, 02:55 PM
528hz's Avatar
0/11 sssss1792
Default Aero port distance from inside box question
So lets say I need an aero port to be 21" long, and the depth of my box is 23" deep.
Therefore the end of the port on the INSIDE of the box would be 2 inches away from the back piece of wood.
Am I OK with this, or is there a certain distance an aero port must be from any of the panels of the box?
Old 10-15-2011, 03:05 PM
0/11 ssssss296
I wouldnt go shorter than the diameter of the port.
e2theloc's Avatar
0/11 ssssss909
I think your good if your port is a 4" aero
Old 10-15-2011, 03:18 PM
528hz's Avatar
0/11 sssss1792
Now, I know that rule applies to the distance of the outside of the port, to say, the distance of my trunk lid. I wasn't sure about the inside...
Thanks for the vode of optimism. I'm hoping I'm good too...
And it will be 2 4" flared aeros to be exact...
Old 10-15-2011, 03:21 PM
kz650's Avatar
0/11 sssssss95
A general rule of thumb is to have the port the diameter of it away from the inside wall. For instance if you have a 4" port it would be ideal to have it 4" away from the inside wall that it is loading off of. I think you should be fine though with it 2" away.
Old 10-15-2011, 04:08 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
From my experience, the port being that close to the inside wall will effect the tuning. It's going to lower your tune being that close. I'd split the difference and make the port 20" and 3" from the inside wall.
Or, unless you don't have room or just plain don't want it this way, make a few inches of it external.
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
528hz (10-16-2011)
Old 10-15-2011, 04:12 PM
528hz's Avatar
0/11 sssss1792
Thanks a lot for the help and advice, guys. I'm just going to increase the depth of my box, being the ports will be firing rearward toward the trunk.
One final question I had is; if the depth of the a box is longer than the width of the box, will this have an adverse effect on anything?
For the record, I'm doing 1 15" up-firing in 3.2 cubes tuned to 30hz. Aero ports will be place on the driver side, firing towards the rear...
Old 10-15-2011, 04:35 PM
Novicaine's Avatar
CACO Late Night Crew
0/11 sssss6135
The rule is a diamater or a radius but really, just do it! For daily the very little shift in expected tunning is not going to be a big deal.
EDIT: Or just go along with what you said in your last post
The Following User Says Thank You to Novicaine For This Useful Post:
528hz (10-16-2011)
aero port box for 4 sa-8's, too much port? Dbmonster (Sundown Audio) 4 08-11-2011 02:08 AM
Aero port question TWiZTiD859 Enclosure Discussion & Design Construction Help 23 06-29-2011 01:52 AM
aero port question More spl General Car Audio Discussion & Questions 4 04-11-2011 09:28 AM
question about aero port oslouie Enclosure Discussion & Design Construction Help 4 03-04-2011 09:43 PM
aero port question cadillac214 General Car Audio Discussion & Questions 13 10-19-2010 01:42 PM
