could some one help me with some box info - Car Audio Classifieds!
Old 10-16-2011, 10:30 AM
1mtx1's Avatar
disabiled,imSIckinthehead
0/11 ssssss720
Default could some one help me with some box info
hey guys could someone help me out here. first i wana say i know there is subs that are ment to b used in spl setups(burps etc) and u have your daily setup. so i have had a few 15s and for the most part in a daily ported box tune to 30-34 would u say a good starting point is 4-4.5 for one 15? allso well where talkin about subs lol how about a single 18 in a daily setup what is the smallest box u guys would go with on lets say rated power wich would b some where in the 2k rms range? i just wana try to get some ideas of how big of a box i gota build for some one and i want him to see that even one 18 might b a big box and he could get some crazy output even with a single 15 and still not kill his cargo area. thanks
Old 10-16-2011, 10:32 AM
1mtx1's Avatar
0/11 ssssss720
if u wana know its a full size tahoe im not sure of the year but i think its late 90s
oslouie's Avatar
0/11 sssss5073
Feedback Score: 69 reviews
It's going to all depend on the sub's specs and recommended enclosure size. I don't think there's a rule of thumb as far as boxes go. Brand A could be recommending 2.5 cubes for their subs and brand B could be calling for 3.5 cubes. They're all different.
Old 10-16-2011, 10:35 AM
1mtx1's Avatar
0/11 ssssss720
i know i was lookin in to dc subs a year ago and i seen they dont call for a large box at all. i was just thinking there was like a starting point i could go from.
Old 10-16-2011, 10:42 AM
oslouie's Avatar
0/11 sssss5073
Not really a starting point. If they call for x.xx cubes tuned to xx hz then just go from there. The enclosures they call for would be if you have the recommended power. If you have less power, then you could make the box a tad bit bigger to compensate for the power. Does that make sense?
Old 10-16-2011, 10:50 AM
1mtx1's Avatar
0/11 ssssss720
oh i understand what to do if u have rated power or less or more as far as what to do with the box. i just wanted to explain to my nephoue that if he goes with a single 15 he still can have some crazy out put kill the lows and not give up his whole cargo area. if we go with sub up port back he can still put stuff back there cuz i dobut he will put anything on top of the sub. i guess i will see what he wants to spend pick out a few diff subs and just go from there. thanks
Old 10-16-2011, 10:56 AM
oslouie's Avatar
0/11 sssss5073
That would work and yes, you can still have crazy output. It's all in the install. You can make some crappy stuff bang but it's gotta be in the perfect install.
Old 10-16-2011, 11:00 AM
1mtx1's Avatar
0/11 ssssss720
i was tellin him the othere night about sundowns new line of subs. i think there is a 15 for 139 i dont know if that is still the price for them. he was liking the idea of 2 of them do to there low rms wich i think is 500 but i think they tested them at around 800 or so with no issue. thanks bro if i run in to any issues when we get the subs picked out i will come back for any needed help. thanks
Old 10-16-2011, 11:35 AM
oslouie's Avatar
0/11 sssss5073
You should look into Obsidian subs too. I have a pair of 12's and love them. They are priced right around that range you're in. Jacob (owner of Sundown) helped with the design. The Obsidian subs would be a step up from Sundown's new line of entry level subs. I don't think you can go wrong with either one but the Obsidians will also take more power.
Old 10-16-2011, 09:56 PM
1mtx1's Avatar
0/11 ssssss720
i spoke to him tonight again and he liked the idea of runing sundown and the new line will fit his needs. pretty much he dont wana have to do much to his electrical. he does have a pretty big stock alt . he did say he is gona do the big 3 in a few days. i told him about knu
Trubass ultra 8'' info/box help LyferXB9s Enclosure Discussion & Design Construction Help 43 09-17-2011 05:48 AM
info Z-10 scfaust (Sundown Audio) 5 09-09-2011 06:32 PM
Box INFO For 2 18'' AQ HDC3 HELP PLEASE extremechevyman67 Enclosure Discussion & Design Construction Help 17 02-28-2011 12:41 PM
info on plexi box build??? bobbygilly Off Topic Chat 40 09-17-2010 08:04 PM
info - hertz on a box by dimensions and vented spl freak General Car Audio Discussion & Questions 1 03-25-2010 05:38 AM
