Four or Six 15s 4th order...Enough space? - Car Audio Classifieds!
Old 10-17-2011, 08:53 PM
Default Four or Six 15s 4th order...Enough space?
The box I have now is coming out tomorrow, and the new build should start shortly. It's going to have even more cone area. Right now I'm debating between 4 or 6 15's, the box would be as follows:
Six 15s: 2 ft^3 sealed/3.5 ported each. 300 watts per
Four 15s: 3ft^3 sealed/5.25 ported each. 450 watts per
Either box will be a wall tuned to 45ish hz with about 280 in^2 of port area.
TSP's:
DC resistance 3.3
Nominal power handling (W) 400
Program power (W) 800
Sensitivity (1W/1m) (dB) 87
Frequency range (Hz) 35-150
Voice coil diameter (mm) 50.8
Voice coil material SV
Former material BAL
Magnetic gap depth (mm) 8
Magnetic(Oz) 48
Flux density (T) 1.1
Fs (Hz) 27.7
Re 3.3
Qes 0.62
Qms 4.18
Qts 0.54
Vas (L) 156.7
Sd (cm2) 0.086
Xmax (mm) 11
Mms (gr) 214.56
Bl (N/A) 14.13
[email protected] (mH) 2.9
Mmd (gr) 200.4
Cms (mm/N) 0.15
Rms (kg/s) 8.96
Goals: Daily, no chopped stuff, no meter, I'd be happy with high '40s in the 35hz range.
Any input?
Old 10-17-2011, 09:04 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
shit id say you had enough for 6
-Youtube Channel
Old 10-17-2011, 09:26 PM
I'm also debating doing more of a 1:1 with a larger sealed chamber and higher (55hz) tuning on the front chamber. I'm just not sure if I would see any benefit from a larger sealed portion.
Old 10-17-2011, 10:17 PM
0/11 sssss1230
2cf is way to big per sub if all 6 are common chamber.
Team Excessive
Old 10-17-2011, 10:32 PM
It would be 2-3 per side, common chamber on each side though. The box would be 45" deep, so 2-3 deep on each side.
Old 10-17-2011, 10:36 PM
0/11 sssss1230
Do 4cf net each side with 16-20cf ported with the previously mentioned port area.
Team Excessive
Old 10-17-2011, 10:59 PM
Cool. Gotta contact someone and get the subs ordered this week.
Thanks for the input.
Old 10-17-2011, 11:21 PM
Novicaine's Avatar
CACO Late Night Crew
0/11 sssss6135
Sounds cool man I hope it turns out good...I'd like to see a vid or pix when its done.
2 15s ported or 4th order? rachidfunaki Enclosure Discussion & Design Construction Help 1 10-26-2010 03:55 AM
DC XL 15s in a 4th order bandpass or ported for daily?? tez4life (DC) 12 10-04-2010 02:35 AM
