18" BTL in too small box.... - Car Audio Classifieds!
Old 05-13-2009, 07:42 PM
aturcotte127317's Avatar
Veteran Member
0/11 sssss3613
Default 18" BTL in too small box....
What will it do? The most i can get without passing the window line, and without taking off panels, is ~5.75 before disp.
What are the cons of doing so?
edit: is it still "below window" if the sub is inverted, and the sub crosses the line? same with ports?
147.5 sealed on dash
149.0 in kick
and climbing
2 12" 2010 Type Rs
or
1 15" DD 9915
Audison VRX 1.500
or
Sundown SAZ1500D
Crescendo 1000C4
SHOK wire
Old 05-13-2009, 07:45 PM
Pioneer~Saturn's Avatar
Idk what Im talking about
0/11 sssss8346
mine was in 4.6 cubes net...but I had around 5k watts going to it...the more power the better, but if you arent running much power to it, the output wont get as high as it could.
Louder. Lower.
Team Tupperware
Old 05-13-2009, 07:46 PM
0/11 ssssss714
Less efficient, reduced low end. I've been squeezing different setups into a reg cab truck for years and I learned the hard way that you're better off just going with the next size down and having extra room than squeezing a big sub in a small space. Just my 2 cents.
Old 05-13-2009, 07:48 PM
Veteran Member
0/11 sssss3613
hmmm i would do a 15", but i already have an 18" and it isnt worth getting it reconed or shipping it (no moneys )
first post edited
149.0 in kick
and climbing
2 12" 2010 Type Rs
or
1 15" DD 9915
Audison VRX 1.500
or
Sundown SAZ1500D
Crescendo 1000C4
SHOK wire
Old 05-13-2009, 07:51 PM
0/11 sssss8346
I believe if the sub or port are above the window line it counts as part of the enclosure and is illegal if youre trying to stay in a no-wall class.
I'd build it and just see what it does...an enclosure wont cost that much
Louder. Lower.
Team Tupperware
Old 05-13-2009, 07:53 PM
Veteran Member
0/11 sssss3613
But i do not have much to spend, or a meter to see if i am happy with it....
I am really trying to avoid taking off any trunk panels, but i am sure i could get 6.5-7 out of it if i did so....
149.0 in kick
and climbing
2 12" 2010 Type Rs
or
1 15" DD 9915
Audison VRX 1.500
or
Sundown SAZ1500D
Crescendo 1000C4
SHOK wire
WTB:Small amp for a 10" L7 splvictim20 Wanting to Buy (WTB) 2 05-09-2009 02:40 AM
small guy amp companies? Snwbrdr1 General Car Audio Discussion & Questions 2 04-18-2009 11:33 PM
WTB SMALL sub amp 92K1500 Wanting to Buy (WTB) 6 03-28-2009 04:03 PM
What small amplifers do you know? C3 Customs General Car Audio Discussion & Questions 5 02-07-2009 08:29 PM
