crap idea? - Car Audio Classifieds!
Old 10-19-2011, 03:17 AM
0/11 ssssss288
Default crap idea?
Sub up, slot port horizontal...or can be sub forward port vertical firing to same side.
Question is, I need it to be in cabin of a 92 Bonneville, how good/bad will this normally play out? She won't let me have the trunk but the 3 belts upfront are good enough for me her and the boy. If up firing the sub will be right about the same height as rear door window line, with up to 12" of port clearance. Can be less if it'd perform better
Hdc3 18 off of 1.5-2kw in a box surreal designed for it but for my midsize suv. Tapered line @31hz (I hope I remembered that correctly) Just need to know it isn't a retarded idea that will most likely give way less output vs when it was in the suv. Reusing box is just out of laziness and to save some cash, not using it isn't out of the question at all.Just a daily driver that will never see a meter.
Fwiw, I'm not just tossing it on the seats lol. False floor to give an even mounting surface for box after I pull out the seats and trunk sealed to hopefully keep from needing to deaden the trunk.
Sorry for the page of text, opinions are useless without knowledge though
Need box help? Pm surreal
Old 10-22-2011, 05:12 PM
0/11 ssssss288
Originally Posted by sableflexn View Post
Thanks for permission :-)
This is a big boy version of my idea. My box would be just about as tall as the baffles in this pic and right about 40" wide instead of the available 54", which is why side firing seems like it might be OK in my under educated opinion if I make sure the door it's firing into is decently solid.
Any reason to not go full throttle on it and start stocking building supplies?
Old 10-22-2011, 05:44 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
if its side firing, it'd load right off of your door. so, make sure that it solid or expect some rattle and potential damage on it.
-Youtube Channel
Old 10-22-2011, 05:54 PM
0/11 ssssss288
Indeed. Deadening that door and roof are the priority spots. thinking about having the neighbor weld on a solid piece over the door skin as a beauty/strength panel.
Anything shy of "it's the dumbest idea ever and won't work well" makes me smile
Old 10-22-2011, 06:32 PM
Raptor660's Avatar
0/11 sssss5243
Feedback Score: 32 reviews
I am running a 18" AA Mayhem in a 1992 Bonneville! LOL.. i'll post pics in a minute of the best box design i found for a trunk set up
2005 Buick LaCrosse
HU: Alpine INE-S920HD
Old 10-22-2011, 06:35 PM
Raptor660's Avatar
0/11 sssss5243
18" AA Mayhem on only 1000rms - YouTube
box is about 6 cu ft.. tuned to 32-34hz.. Chit is LOUD!
2005 Buick LaCrosse
Old 10-22-2011, 06:39 PM
Raptor660's Avatar
0/11 sssss5243
o sorry just noticed u didnt want it in the trunk... I also had a large 6.5cu ft box in my back seat sub and port to passanger side and it was real loud.. I dont recommend taking up the whole back seat and having ur son side in the middle up front.. its just a lapband seatbelt so if u hit something he is just gonna get bent in half and hit his face into the dash.. not good bro..
This was just a temp setup obviously. lol
2005 Buick LaCrosse
Old 10-22-2011, 08:18 PM
0/11 sssssss25
Nice vid
Oh Crap what could this be for 2000LaDe (Sundown Audio) 60 10-03-2012 07:01 PM
Good idea or Bad idea? Ccab81 General Car Audio Discussion & Questions 6 02-16-2010 06:31 PM
WHAT to get this crap off with?! Rd4me General Car Audio Discussion & Questions 11 10-27-2009 03:57 PM
New enclosure idea, but I have no idea how to calculate it... 98AckCL23 Enclosure Discussion & Design Construction Help 15 08-21-2009 04:45 PM
oh crap need help korey_hofer General Car Audio Discussion & Questions 14 04-17-2009 10:22 PM
