box size, port area for crossfire xsv2 18 - Car Audio Classifieds!
Old 10-19-2011, 07:21 PM
0/11 ssssss236
Default box size, port area for crossfire xsv2 18
like the title says. anyone have any hands on experience with these subs and what works good for them in loud daily applications? this will be powered by a ia40.1 on .5ohm
i am gonna do a single sub wall in my honda civic for now.
before anyone says anything i have a 300amp alt on the way and buying a few deka 9a31's for the back.
Old 10-19-2011, 07:41 PM
HACKMUNCH's Avatar
0/11 sssss3892
i had mine in 6.5cft 85" port area tuned to 33 hz. best i did with crossfire was 148.7 on ab 500.1 @ 38hz
TEAM TSA 2013
FACTORY BACKED
XS POWER - 4XSPOWER.COM
PSI - PSICARAUDIO.COM
Old 10-19-2011, 07:51 PM
0/11 ssssss236
was that on music or tones? what kind of vehicle? no wall i take it?
Old 10-19-2011, 07:56 PM
HACKMUNCH's Avatar
0/11 sssss3892
no wall in hummer h3 with sht electrical. thats with tone did low 148 on music
TEAM TSA 2013
FACTORY BACKED
Old 10-19-2011, 08:04 PM
0/11 ssssss236
oh ok thanks. doesn't sound to bad considering the application.
Old 10-20-2011, 08:00 PM
0/11 ssssss236
nobody else? google isn't yeilding the best results. not all that much info out on these subs that i can find.
Old 10-24-2011, 04:04 PM
AbsoluteAudio's Avatar
0/11 sssss1133
Sick woofers! I have ran every size xsv2 they make from a custom 10" to the 18". They will take a sh!t ton of power also. every setup i have used them in was daily. Including jpassage on here (152db on the Tl on music in a scion tc). How much power are you looking at running to it?
Old 10-24-2011, 07:48 PM
0/11 ssssss236
i'm gonna be running a ia 40.1 on 1 or .5ohm
wish i could find a little more info on them. maybe you can pm me with some details or things they like.
Old 10-25-2011, 04:03 PM
0/11 sssss1133
40.1=3600x1 @1ohm 14.4v. If it was me doing a daily box for rap-hiphop, I would say 6.5cuft after port and sub displacement, tuned to 32hz with around 85sqin of port. It will do well on a TL and still kill the lows on music!!!!!!
Old 10-25-2011, 05:24 PM
0/11 ssssss236
Ok thanks.
Also the amp is very under rated from clamp numbers I have seen online. Doing more like 4500+
Not sure if that changes the design much?
Walled scion tc 2 18'' crossfire xsv2!! jpassage24 Miscellaneous Build Logs 7 08-11-2011 07:18 PM
SA 15s box size and port area help?? tez4life (Sundown Audio) 4 05-20-2011 03:49 PM
15in Crossfire XSv2 specs bread0710 General Car Audio Discussion & Questions 15 05-16-2011 07:10 PM
burnt up crossfire xsv2 tinsel leads 9515ROB General Car Audio Discussion & Questions 45 04-25-2011 03:42 PM
2 crossfire xsv2 on 2 stetsom 14k 9515ROB General Car Audio Discussion & Questions 29 09-08-2010 03:19 PM
