Box help 2 18s in a 98 blazer - Car Audio Classifieds!
Old 10-19-2011, 09:04 PM
thekernal123's Avatar
0/11 sssss1813
Default Box help 2 18s in a 98 blazer
Trying to fit 2 18 audio que in the trunk area of my blazer my maxes are 39x25x30 lookin to tune it low to anybody care to help?
98 blazer dc 320amp alt 1xs d3100 a 2 type r 15 d4 at 1 ohms on a AQ 3500 doing a 148.5 at 41htz so farrr gotta do some adjustments
Old 10-19-2011, 09:16 PM
Jokerr's Avatar
0/11 sssss2279
Feedback Score: 33 reviews
Go with 15s..
I buy blown amps,
Old 10-19-2011, 09:34 PM
duff_thrust's Avatar
0/11 ssssss629
That's plenty of room for 18s. Plenty of port area is capable with this size and how does 34 hertz sound. Is that low enough?
Old 10-19-2011, 09:45 PM
0/11 sssss1564
Its not plenty of room for 18's .... you need to step it over the wheel wells.. doing this will get you around 10.5-12 cubes. Its a very tight squeeze but it can be done. I have my tuned to 27Hz .. its low but takes my net to ~10.4 with 135 sq in of port. Try to aim around 14-16 sq in per foot.
u scratchn ur ass or your head, but it could be both cause your heads in you ass.
Old 10-19-2011, 10:03 PM
NoPh33rRaCiNg's Avatar
I <3 ( . )( . )'s
0/11 sssss3010
Feedback Score: 29 reviews
This ^
I had 2 15's in mine which was just enough, tuned little higher.
Team DC Audio : Team NWSPL : Team Shok
02 Tahoe - (1) 15'' XL, Shok II, Shok 1/0
03 S10 (in progress) - (3) 15'' Lvl5's, (2) DC 5k's, lots of Shok 1/0
Old 10-19-2011, 10:29 PM
0/11 ssssss629
origional dimensions given were 39x25x30. I went 38x25x28 into 2 different box design programs I use. 13.15 is gross on those dimensions. With subs up and port up I can get 150.00 sq in of port which is 14.10sq in per cubic foot. final tuning on this was 34.94 hertz and net volume after port displacement was 10.64 cubes. So... 5.32 cubes per AQ 18 is plenty of airspace with an adequately efficient port. ?'s
Old 11-25-2011, 03:30 PM
0/11 sssss1406
if your stuck on it go for it but id tune lower like 28 to 30 ( their 18s cmon now )
Old 11-25-2011, 03:31 PM
Decaf's Avatar
0/11 sssss3460
Feedback Score: 24 reviews
herro... told you id help ya if you need it
TeamGG
Team D.O.A.
Old 02-03-2012, 04:30 PM
EdgarCervantes's Avatar
0/11 ssssss600
Id your still onto this, you should check out my build log i fit 2 18s back there!
1999 Chevy Blazer 4 door, DC Power 270 Xp, 4 runs of Stinger HPM, 4 C&D 100 ah
AQ 3500.1, AQ 90x4
Loudest 17 Year Old In Cali
Team Skar
Team Sundown
Blazer box help!!!! LyferXB9s Enclosure Discussion & Design Construction Help 16 10-09-2011 11:30 AM
DC Audio Blazer LVL5 18s Walled! loudnlow931 Build Logs 86 08-29-2011 01:35 PM
2000 Blazer 4dr (2) Fi Q 18s SoCaLBaMF Build Logs 7 04-14-2011 05:05 PM
1999 Blazer+ 4 fi btl 18s and a SD8k Justin Team SounDigital 80 04-12-2011 10:47 PM
Blazer + 4 FI BTL 18s = FUN! Justin Build Logs 34 11-14-2010 06:55 PM
