Box help for 15" re xxx - Car Audio Classifieds!
Old 10-19-2011, 11:39 PM
0/11 sssssss29
Default Box help for 15" re xxx
I got a 15" RE XXX (later model) for one of my cars and I need some help with the box. I see RE specs are 1.6 to 2.1 cubic feet sealed and [email protected] ported. The biggest box I can fit on the space I have its about 3.5 or so.
Now while searching I found that some people didn't like the way it sounded in boxes build to RE specs. They found that it sounded better when they closed the port. So in the end they ended with a box that was 3.2 cubic feet sealed. Anyone here have experience with them??
Old 10-19-2011, 11:49 PM
thekernal123's Avatar
0/11 sssss1813
4 cubes after displacement tuned to 32 it will sound amazing and how much power do u have?
98 blazer dc 320amp alt 1xs d3100 a 2 type r 15 d4 at 1 ohms on a AQ 3500 doing a 148.5 at 41htz so farrr gotta do some adjustments
Old 10-20-2011, 12:18 AM
0/11 sssssss29
Not sure if that size box would even fit properly. I got 2 soundstream LW1.1100d (2200rms at 2ohms linked) I forgot which model kinetik batt and I still got to buy a HO ALT.
Old 10-20-2011, 08:15 PM
0/11 sssss1813
3.5 would work also tuned loww those subs destroy the lows
Box Build for a 15" SS XXX GetLikeMe Build Logs 21 11-22-2010 11:42 AM
15" Soundstream XXX rebuild and new box. boboridesbmx Build Logs 6 11-17-2010 04:33 PM
Need box idea(s) for 2 old-school 18"XXX in a '10 Tundra Double Cab hollatchaboy Enclosure Discussion & Design Construction Help 6 04-19-2010 08:19 PM
box suggestion for re xxx 12" reaudioxxx Enclosure Discussion & Design Construction Help 0 04-14-2010 06:10 PM
Box for (1) '05 RE XXX 12" Cheesemind Box Requests 7 11-03-2008 07:48 PM
