Experienced SPL Guru's box ? - Car Audio Classifieds!
Old 10-20-2011, 07:29 PM
e2theloc's Avatar
0/11 ssssss909
Default Experienced SPL Guru's box ?
is there going to be a difference mounting a flared aero port internally or externally to the box?
obviously external mounted gives you more net volume. but im talking besides that. has it make a difference on the meter for you guys?
i would think external would be better but maybe there is no difference at all
Old 10-20-2011, 07:31 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
It's application dependant, but external is almost always a gain. Could be a tenth or two... could be a whole db. You just need to test.
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 10-20-2011, 07:36 PM
MopaRBumpiN's Avatar
0/11 sssss3819
Feedback Score: 35 reviews
Alot of vehicles have there boxes firing into the rear driver quarter panel. Porting external allows the ports to be one side of the vehicle while the subs are on the other side.
Team DefJ, Team XS Power, Team Audio Technix
Headunit: Pioneer DEH-80PRS
Tweeters: Vifa XT25
Midbass: Silver Flute 8"
Highs Amps: Soundstream TN4.900
Sub: Cascade Design Omega 15"
Sub Amp: Incriminator Audio 20.1
Electrical: XS Power D2400, XS Power D3100
Deadener: Alpha Damp and Audio Technix 80 mil
Old 10-20-2011, 07:38 PM
e2theloc's Avatar
0/11 ssssss909
well im probably going to end up testing both, but if i design the box for external, and then mount it internal im going to be losing space inside the box which is a change as well...so i wont know for sure if it was the box being smaller that made me gain/lose or the port being in or out....im going to start with external tho.
Old 10-20-2011, 07:44 PM
e2theloc's Avatar
0/11 ssssss909
Also...to 45 or not to 45? box is sub firing up and port on the side. ill try to get you guys a pic if you need one.
Old 10-20-2011, 07:57 PM
0/11 sssss3819
Alot of people lose output when 45ing in an aero box
Tweeters: Vifa XT25
Old 10-20-2011, 10:48 PM
e2theloc's Avatar
0/11 ssssss909
is there a good difference between using a thick doll rod or a threaded metal rod? id like to use the metal threaded but idk how i would cut it. also if i were to brace the box vertically with the threaded rod wouldnt the rod stick out the bottom of my box? causing it to sit funny
Old 10-20-2011, 10:54 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Believe it or not, "dowel" rod still flexes so the all-thread is the better choice there. There is also no really great way to attach dowels so that's also a weak point.
I use my Dremal to cut it. Or a hacksaw. As far as vertical bracing, obviously you may not be able to do this with the all-thread due to the reason you mentioned, so dowels or even a scrap piece will be better than nothing.
But honestly, you really only need bracing once a box gets to a certain size or power level.
4x world champ
- Floyd E. Toole
e2theloc (10-20-2011)
Old 10-20-2011, 11:00 PM
Me > Lord Van
0/11 sssss2831
I will say that 90% of the time external mounting will be a gain.
There are several reasons for this.
1) Smoother airflow in the box
2) Smoother airflow between the air mass inside the box and the air mass in the port
3) Easier tuning changes (which can greatly increase your score)
The one big BIG thing you need to test with an external port is different lengths. This can GREATLY affect your score. Just because a box is "tuned" to a certain frequency does not mean it will peak at that frequency. I've had some boxes gain anywhere from 1-4 dB just by changing the port length.
The nice thing about having the ports mounted externally is that they are easily changeable. Also, when you change the length you won't be changing the net volume of the enclosure like you would be if the ports are mounted internally. Just one other benefit of externally mounting them.
As for 45's and bracing, I advise to test the enclosure absolutely PLAIN before doing anything to it. This includes resin. You won't know what hurts or helps you if you don't have a baseline number to go off of.
Also, don't neglect the outside of the box as well. Rounding off corners, resin, etc. on the outside the enclosure can help as well.
Team DOA
10 inches of terror
One DD 9510F + one kicker zx2500=150+ db
One Sundown SA-8 + 2 mb quart 2000's = 150+ db
-2006, 2007, 2009, and 2010 MECA World Champion
-2008 Bassrace 130-139.9 National Champion
Old 10-20-2011, 11:03 PM
18inchjeepin's Avatar
0/11 sssss1931
Feedback Score: 37 reviews
i think that external aeros are a gain because of the air flow going strait out of the port, not having restictions if it were inside
remember SPL is all about efficient air flow
damn you tommyk
Silver HHR
TEAM SOUNDSTREAM
XS Power D3100 with Toolmaker blocks
Alpine 9884-> Soundstream RUB4.600-> Soundstream SST-05 tweets-> Soundstream 804N 8" neo mids
A-pipe mini 1500-> pair Sundown SA15's -> 4th order wall
Need Help From Experienced No Wall Box Builders Bigpimpin91 Enclosure Discussion & Design Construction Help 26 10-02-2011 06:43 AM
Need help from the experienced.... jhg33k General Car Audio Discussion & Questions 5 09-11-2011 03:06 PM
Experienced box builders question Boomintahoe Enclosure Discussion & Design Construction Help 7 10-15-2010 08:48 PM
