advanced enclosure help - Car Audio Classifieds!
Old 05-14-2009, 06:08 PM
Default advanced enclosure help
ok well I wasn't going to post this until I built it but I need help so
would this do what I am thinking
so it's basically a chambered t-line and jl ho box mixed together this one was designed for 2 aq 12';s but hinking of one to do for my type r 10's to see how it sounds
basically just need to know if this is gonna have the gain on the low end of the t-line and the handling of the ported box both waves should be going in the same direction out the front port which is tuned to 70hz I think while the line is tuned to around 32
Old 05-14-2009, 06:19 PM
HiloDB1's Avatar
0/11 sssss3158
That line looks short to be tuned to 32Hz.
Old 05-14-2009, 06:23 PM
yeah it is it's tuned to 43hz the fs of the sub mybad
Old 05-15-2009, 12:54 AM
No, I'm not dead
0/11 sssss8128
Okay, I'm lost here. A t-line tapers, that's just a slot port. The only non tapering T-line I've seen is a long rectangular box with the driver near the top and a simple hole about 1/3 of the way up from the bottom (with the enclosure upright on the long side). It's fairly narrow across the width of the baffle and shallow but the depth is uniform.
All the others taper with the woofer at the widest part of the taper or a short distance down.
Old 05-15-2009, 01:06 AM
alot of them are full width the tappered ones dont have as much of a spike at tuning I was to lazy to model up a tapperd line and then fold it to
Old 05-15-2009, 01:11 AM
No, I'm not dead
0/11 sssss8128
Okay but shouldn't the area the subs mount in be the same size as the rest of the line? To my eye that just looks like an ordinary ported enclosure with a big port. A smallish enclosure mind you but still...
Old 05-15-2009, 01:14 AM
chambered t-line has a small box area but still has the full size line helps load the sub so it doesn't max out as soon pwk does alot of these enclosures toyotat thundra had a chambered t-line in his first pick up
Old 05-15-2009, 01:19 AM
No, I'm not dead
0/11 sssss8128
Ah. Must be something fairly new. I bet that port on the enclosure proper will get a bunch of air movement.
Old 05-15-2009, 03:09 AM
HiloDB1's Avatar
0/11 sssss3158
This is reminiscent of one of PWK's "phase box's". How did you calculate the tuning of the "front port"?
Enclosure for 2 15 XXX Silver-N-black Enclosure Discussion & Design Construction Help 10 04-28-2009 12:32 PM
Enclosure help for btl Team3d Enclosure Discussion & Design Construction Help 0 04-16-2009 08:45 PM
Enclosure for MTX 9510-44 Help ProjectPechkin Enclosure Discussion & Design Construction Help 1 12-25-2008 01:48 PM
Advanced Question About Ohm Load only126db General Car Audio Discussion & Questions 13 12-16-2008 11:22 PM
