when it rains it pours - Car Audio Classifieds!
Old 05-17-2009, 04:41 PM
scfaust's Avatar
0/11 ssssss848
Default when it rains it pours
well now new proublem... my box in my exporer is rattling i thought it was the truck but after looking closer i found it was the box the port in the midle is ratling like crazy if i put my hand in it it stops if i press down slightly so i dont know what to do i had put a board at the end to sapport it with liquide nails and resin also put it in with liquid nails and resind over top of that it just started and ive been bumpin for a while.........heres my build thread check out the box its just the 1 port
Old 05-17-2009, 04:48 PM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
Build thread?
/ CAAA Member #2 /
Old 05-17-2009, 04:50 PM
scfaust's Avatar
0/11 ssssss848
sorry happy birthday to me 4-17-76
Old 05-17-2009, 09:09 PM
craiggus365's Avatar
Partially Unwound
0/11 sssss2697
How about cutting a square of MDF with a circle cut out for the port and slide it from the inside to give extra support at the base of the port inside the box. This way you have the base of the port passing through 1.5" of mdf instead of .75". That combined with liquid nails and a couple screws should hold it steady. If you already braced the inside ends of the PVC just cut the circle in half to make 2 arches and "clamp" them around on the inside base of the port, then glue and screw.
Hope this is clear
and helps
