67.5in^3 = port noise? - Car Audio Classifieds!
Old 05-18-2009, 03:40 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
Default 67.5in^3 = port noise?
using a 18" RL-p based sub. 13.37ft^3 box with 67.5in^3 of port, tuned to 20hz. think i'll get any port noise with this? or should i go a little bigger.
Proud Member of CAAA!
Old 05-18-2009, 04:12 PM
0/11 ssssss714
How much power? I would definitely think you'll get port noise. I have that much port area for 4.2 cubes!
Old 05-18-2009, 04:19 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
850rms. i had a 15 running with 48in^3 without a problem, but this will be my first build for a 18. and since it will be HT, i can't have any noise other than the sound of shat getting blowin up and such.
Old 05-18-2009, 04:50 PM
0/11 sssss3638
sounds a little small
Old 05-25-2009, 11:53 PM
Ami Creations's Avatar
Loyal Member
0/11 sssss1064
Are you just using 1-18?
Old 05-25-2009, 11:55 PM
No, I'm not dead
0/11 sssss8128
You're talking about area or total port volume? Area is square inches not cubic inches...
Wiring Problem, Getting Ground Noise BassikInstincts General Car Audio Discussion & Questions 7 04-03-2009 03:08 PM
ground noise? caps General Car Audio Discussion & Questions 19 03-02-2009 07:10 PM
Amp noise. *Need help quick* Bushj311 General Car Audio Discussion & Questions 23 01-14-2009 11:18 PM
Head unit noise??? Mojo General Car Audio Discussion & Questions 20 12-19-2008 10:13 PM
a whine/ screah noise noise from my sub aturcotte127317 General Car Audio Discussion & Questions 27 10-28-2008 07:50 AM
