port area - Car Audio Classifieds!
Old 05-19-2009, 11:49 PM
lantz's Avatar
0/11 sssss1030
Default port area
how do you determine how much port area a sub needs.Rockford told me 256sq.in and 12cu.ft box for my TRF2215 sub and somebody else told me tw0 6" round ports and a 5cuft box........this is very aggravating! i have specs if that would help.
Rockford Fosgate TRF2215
nominal diameter......15in(381mm)
magnet weight...400 oz.(11,340g)
frequency response....38-200HZ
nominal impedence...2 x 1.5 ohms
DC resistance(RE)....2 x 1.4 ohms
Resonance Frequency(Fs)....38Hz
Total Q Factor(Qts).....0.27
Electrical Q Factor(Qes)....0.28
Mechanical Q Factor(Qms)...4.328
Effective Cone Area(SD)....133in^2 (0.086 m^2)
Equivalent Air Volume (VAS)....2.23 ft^2 (63.1L)
Compliance (Cms).....6.13E-05 m/N
Moving Mass (Mms)...9.95 oz(282g)
Voice Coil Diameter.....4 in (102mm)
Voice Coil Winding Width....2.42 in (61.5mm)
Voice Coil Former Material....8 mil aluminum
Voice Coil Inductance......2.92 mH
Force Factor(BL).....26.33 Tm
Linear Excursion (Xmax)....0.61 in(15.5mm)
Sensitivity(SPL)....93.1dB
Operating Power(PE)...2000W RMS/4000W Peak
Mounting Diameter...13.813 in (351mm)
Mounting Depth...9.3 in (236mm)
damn thats alot of typing...LOL!!
i had this in the recommended 12cuft box with 256sqin port area but i didnt know jack about tuning so i only had it 6" deep....LOL!! still hit a 146db.
now i have a 5cuft box with two external 6" pvc ports that are about 20" long....sounds like crap though.
any suggestions on ports would be appreciated.
oh....i dont have ANY room to face the ports to the rear so i thought about replacing the pvc ports and adding an external slot port but dont know what port area to use...thanks!!
Old 05-20-2009, 12:00 AM
who in the hell told you to put 1 15 in a 12ft box
I would do 4ft tuned to 38hz with 80" of port
Old 05-20-2009, 12:04 AM
lantz's Avatar
0/11 sssss1030
That was straight out of the mouth of one of the Rockford Fosgate Reps.ive talked with several old members of team rockford and they said that 12cuft was too much and that they just played around with making different boxes until they found one that worked the best....i dont have that much time or money to be making alot of boxes...LOL!!
Old 05-20-2009, 12:07 AM
well for those type subs I usually go small and a lot of port
oh and alot of power
Old 05-20-2009, 12:11 AM
lantz's Avatar
0/11 sssss1030
well,i have a memphis 4k on it right now but i only wired it at 3 ohms until i get my box right.
Old 05-20-2009, 12:42 AM
Slam's Avatar
I slam
0/11 sssss3772
i might have missed it but is this for a burp box or daily?
Old 05-20-2009, 12:44 AM
lantz's Avatar
0/11 sssss1030
well i kinda want it for both.i figured i might can make some sort of plug for it....or does that sound stupid?
Old 05-20-2009, 07:34 PM
andrew198501's Avatar
0/11 ssssss873
i would just make 2 different sets of aero ports (what i do) just find the lengths you need and also between 4.0 cubes and 5 cubes.....just my 2 cents
Click here^^^^^^^^
Old 06-01-2009, 03:39 PM
lantz's Avatar
0/11 sssss1030
would it hurt to have a slot port that is 34" x 2.5" or does it have to be within 1:8 ratio?
Old 12-27-2009, 02:50 AM
maxpsca@yahoo.com's Avatar
0/11 sssssss96
5 cu ft net volume? try a 90 sq inch port. 6"x15" and 20" long. that a tuning to about 37 hz
Understanding Port Area. 350zkid General Car Audio Discussion & Questions 30 05-20-2009 12:11 PM
Port area for 2 DD 2512's. Drunken.Swagger General Car Audio Discussion & Questions 0 04-09-2009 09:02 PM
Chicago area rdaudioman1256 General Car Audio Discussion & Questions 21 01-08-2009 09:53 PM
wtb crx in great lakes area sholiz Wanting to Buy (WTB) 3 09-18-2008 01:42 AM
How to: Figure port area SPL Guru Tutorials & Quick References 3 08-04-2008 11:24 AM
