how big of a diffrence - Car Audio Classifieds!
Old 05-29-2009, 11:49 PM
scfaust's Avatar
0/11 ssssss848
Default how big of a diffrence
how big of a diffrence will i see if i built a new box same size but tune it to 40hz insted of 35hz
Old 05-29-2009, 11:53 PM
bones22's Avatar
0/11 ssss12257
you may see some gain in score but mid 149's is pretty good. you make pick up a couple tenths.
Old 05-30-2009, 12:10 AM
justin smith's Avatar
0/11 ssssss653
do you have the xl's or just reagular level 4's
Old 05-30-2009, 12:11 AM
scfaust's Avatar
0/11 ssssss848
just level 4s. also if i step up to xl's or 5's with same power would i gain?
Old 05-30-2009, 12:17 AM
0/11 ssssss653
i dont know if off the 1 3000d the xl's would be louder, thats install dependent. but if you got youre subs reconed to xls/lvl 5's and got another 3000d i think your score would jump up a lil-bit with the right box, charging and such
Old 05-30-2009, 12:18 AM
bones22's Avatar
0/11 ssss12257
you may see a gain from rebuilding the box. i dont think you would see much of a change if any just swapping the subs. once you get into the #'s you are at now or higher its a bitch picking up even a tenth
