Originally Posted by jt_buck
Meh, you could make one, but it won't be all it can be.
How much bigger does it need to be? Its my stupid trunk hinges that are getting in the way, otherwise I could get almost a whole extra cubic foot.
I was told I need 1.5 sealed and 2.5 ported, thats what other people seem to be doing as well. Around there.
I made it a bit bigger. Change the 42 1/2" to 43" and I made the height 12.5". Makes it 5.43ft^2 not taking into account material thickness (3/4")
I cant figure out how many cu ft that back section is with the slants.. I know how many it is not taking into account material thickness but cant figure it out when doing that. Help?
I know the box is around 4.0-4.1cuft after MDF displacement.
I may be able to make the 13 1/2" a bit longer.. I probably have another 2 inches, Im just concerned about the corners of the trunk not letting the box go all the way flush against the back. I'll check tomorrow in the daylight, I know I can do 14", if I could do 15" that would be better. Just going to 14" gives me an extra .15 cu ft..
How short am I
