Which 4th order wall design should I do with?? - Car Audio Classifieds!
Old 02-20-2012, 01:56 AM
46panel's Avatar
0/11 sssss1662
Default Which 4th order wall design should I do??
So I will be using my new 10 15" Obsidians and am debating how I want the lay out of the subs. I will either be doing 4 on each side firing at each other with the baffles being on an angle and then having two subs in the very back firing forward (like jp's build) or just do 5 subs per baffle on each side. Obviously both I will make sure have the proper airspace. I would like to put the two in the very back just because I would like the looks of that but just what opinions, pros/cons?
2007 Chevy Impala: JVC KW-V10, Sundown Nightshade 15", Planet Audio Big Bang 2400, Alpine MRP F450, JBL P660C components.
Old 02-20-2012, 12:20 PM
46panel's Avatar
0/11 sssss1662
Any ideas?
Old 02-20-2012, 12:30 PM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
Did you get your idea from JP's 4th?
This would be the way i would do it if I were doing it the way you showed.
Old 02-20-2012, 12:41 PM
mega fatty
0/11 sssss6008
Any way to fit 2 more and have 6 per baffle?
It would have a even look and preform nicely
07 mazdaspeed3
rd d9 @ .5ohm
Old 02-20-2012, 12:43 PM
0/11 ssssss267
so would you do a front on that and port?
Old 02-20-2012, 12:58 PM
46panel's Avatar
0/11 sssss1662
Not enough room...
I would assume having a loading wall would make it better?
But yea I honestly like the look of jp's just don't know if it would perform better if I just went with 5 per side.
Old 02-22-2012, 11:51 AM
0/11 sssss1564
I think JPs design is def. different... try it out
u scratchn ur ass or your head, but it could be both cause your heads in you ass.
Old 02-22-2012, 12:02 PM
46panel's Avatar
0/11 sssss1662
Eh don't think it's worth the risk. To many ppl say it is more susceptible to having issues with having the two in the back. I definitely like the looks of it that way tho.
Old 02-25-2012, 07:15 PM
0/11 sssssss70
I can do a design for you if youre interested.
Old 02-25-2012, 07:23 PM
46panel's Avatar
0/11 sssss1662
I appreciate it, but I really think it is just going to be best to see what type of space I actually have to work with once I get the new baffles made and figure out if the depth of the subs are going to be a problem.
4th order wall? tommytee General Car Audio Discussion & Questions 16 01-27-2012 03:01 PM
Which 4th order wall design should I go with 46panel General Car Audio Discussion & Questions 21 05-22-2011 02:58 PM
4th order wall? Russellabt General Car Audio Discussion & Questions 0 05-21-2011 06:50 PM
Sa15's in 4th order wall hdman87 (Sundown Audio) 64 03-14-2011 09:27 PM
Good 4th order wall design for 4 18" LVL4's Josh Wahlie General Car Audio Discussion & Questions 1 01-26-2011 12:45 AM
