4x vvx-10s 4th order trunk help! - Car Audio Classifieds!
Old 02-20-2012, 12:21 PM
SacTownBully84's Avatar
0/11 sssss3682
Feedback Score: 51 reviews
Default 4x vvx-10s 4th order trunk help!
I'm wanting to try a stab at my 1st 4th order box in the trunk on my 98 Taurus .....Max dims are 17" tall 32"deep 34"wide......four skar vvx10s on a soundstream dtr3400. If i build box inside i can get 9.5 gross ballpark....any help would be greatly appreciated ...thanks
98 Taurus
: CRESCENDO : AT : SKAR : MEMPHIS :
Skar zvx-15 d1
3cubes net @ 30hz
NENDO 3KWP @ .5 ohm
TEAM FUK YO COUCH
Old 02-20-2012, 12:28 PM
Skillz's Avatar
0/11 ssssss907
checkout this thread if you haven't seen it already
Old 02-20-2012, 01:28 PM
0/11 sssss3682
I forgot bout that..........can u email or pm me specs of that box please! ....
[email protected]
98 Taurus
Skar zvx-15 d1
3cubes net @ 30hz
NENDO 3KWP @ .5 ohm
TEAM FUK YO COUCH
Old 02-21-2012, 03:49 AM
0/11 sssss3682
ok found sum great reading material on 4th order design....figured out what technical specs i need now to just turn that into a cut sheet basicly....heres what i got...
4 Skar vvx-10s D2 on a SS DTR3400
BANDPASS 1st design!
3.91 Cu.Ft. Sealed
3.56 Cu.Ft Ported
QTS - .42
Vas - .86520 cu.ft.
FS - 26.6
vf - .879 each driver
vr - .977 each driver
Qbp - .9
Fb - 56.7 hz
gain - 2.87 db
passband - 34-95hz
Port size - 7x9x8.28 @ 34hz
98 Taurus
Skar zvx-15 d1
3cubes net @ 30hz
NENDO 3KWP @ .5 ohm
TEAM FUK YO COUCH
Old 02-22-2012, 05:48 PM
surreal's Avatar
0/11 sssss2489
Generic calculators normally arent great but if jts correct, generically it appears fine. Should give good bandwidth. The skars are pretty funny subs to design for though. Let us know how it goes!
Two Skar VVX 12"s in a 4th order. CousinVin Build Logs 79 12-24-2011 03:45 PM
Jamals Maxima 2 10s 4th order trunk build ridintwo6s Build Logs 12 04-25-2011 07:47 PM
