Need a box design for an ext cab S10 - Car Audio Classifieds!
Old 02-21-2012, 12:05 AM
0/11 sssssss14
Default Need a box design for an ext cab S10
I want to put 2 AQ HDC3 18's in an S10 tuned to 30hz, anyone have anything?
Old 02-21-2012, 12:07 AM
badmofo529's Avatar
0/11 sssss3329
wall? cause that aint gonna fit otherwise
'97 chevy s10
-kenwood x994
-image dynamics ctx 6.5 cs
-2 aq sdc 2.5 15's
-aq 4x90
-aq 1200
The Following User Says Thank You to badmofo529 For This Useful Post:
iamsonic (02-21-2012)
Old 02-21-2012, 12:11 AM
0/11 ssss31258
year?
toad559's Avatar
0/11 sssss1508
if non wall your better off with 2 15s. unless you gonna want the box blocking your rear view. 2 15s non wall on a good5-7k amp, you be burping a 51 easy with the right stuff. those s10 back seat floor sits low so a dual 15 box non wall, you can still be under the window line.
Old 02-21-2012, 12:12 AM
badmofo529's Avatar
0/11 sssss3329
even with 2 15's your raping the dash lol. i know from experience lol
'97 chevy s10
-kenwood x994
-2 aq sdc 2.5 15's
-aq 4x90
-aq 1200
Old 02-21-2012, 12:18 AM
0/11 ssssss767
forget a wall you dont have enough depth. what you need to do is a blow through where the subs are still in the cab but the bulk of the box is in the bed then you can do sub forward and port up or port for ward. i personally think you should do the port up it will have to have a bend but it can be done and it will be the loudest and best sounding.
Old 02-21-2012, 12:20 AM
badmofo529's Avatar
0/11 sssss3329
2 18's WILL fit in a wall. no problem
'97 chevy s10
-kenwood x994
-2 aq sdc 2.5 15's
-aq 4x90
-aq 1200
Old 02-21-2012, 12:23 AM
0/11 ssssss767
this would work well but not for 15inch hdcs becouse they would need 8 cubes after dis placement. you just cant get that much and still drive comfortably at all
Old 02-21-2012, 12:25 AM
badmofo529's Avatar
0/11 sssss3329
i can... i have 8.63 net...
'97 chevy s10
-kenwood x994
-2 aq sdc 2.5 15's
-aq 4x90
-aq 1200
Old 02-21-2012, 12:26 AM
0/11 ssssss767
not enough depth my friend it will load like crap and have insane rise.
Single sa15 d4,on vfl100.1 s10 ext cab atomic_bronco2 Off Topic Chat 4 05-11-2011 11:10 AM
Good Box design for a 94 ext.cab GMC (unerseat) maxdout918 Enclosure Discussion & Design Construction Help 1 04-03-2011 02:26 AM
Wally from Ocean City, MD walled ext cab s10 Dr.Knock08 New Member Orientation 1 03-17-2011 09:13 PM
sub box for 95 chevy ext cab 95chevy Enclosure Discussion & Design Construction Help 3 02-18-2011 06:54 PM
