Question about port up vs port back - Car Audio Classifieds!
Old 02-22-2012, 04:11 AM
916slapin's Avatar
0/11 ssssss825
Default Question about port up vs port back
I want to put some 18s in my blazer I have roughly 14 cubes to work with if I do port back subs up but if I do port up subs up I have about 16 cubes to work with my question is if I do port up subs up will that affect me moving hair
Old 02-22-2012, 04:37 AM
Burbarry's Avatar
Can you hear me now?
0/11 ssssss898
How many 18s are we talking? And what type of power? Ect...
Sent from behind you!
Chrysler 300 on 24" Menzari's
Alpine 9887 Sundown SAZ-1500 3-10" SAs Walled off
Old 02-22-2012, 04:41 AM
916slapin's Avatar
0/11 ssssss825
2 custom made 18s they are 2k rms they will get 4k rms also my truck is a 98 4 door if that helps
Old 02-22-2012, 07:39 AM
Burbarry's Avatar
0/11 ssssss898
With only 2 18s i think you should be ok with subs up and port back. From what ive heard it is louder with port back then up. I am assuming you are going to build a box with about 6cuft for each sub that leaves you with 2cuft for displacement of subs and port. That will be pretty close depending where you tune it to. Might have to cut the box size down a little bit or look into using aero ports instead of slotted. With aero ports you could save internal cuft by putting the ports on outside of the box with a 90degree and fire at back drivers side.
Also, what is your goal daily or spl?
Old 02-22-2012, 08:13 AM
99Bonney's Avatar
0/11 sssss6246
When firing back how much room do you have to the hatch? If its not very much then I would port up. Look into aeros to save on space.
2006 Tahoe
Subs- 4 Crossfire xs v2 15s
Amps-Crossfire 8k
Batts- 6 xs 3100s, 2400
Alts- 3 Mechman SMD 340s
Old 02-22-2012, 10:55 AM
916slapin's Avatar
0/11 ssssss825
About 5 inches I want to tune it to 30 hz
Old 02-26-2012, 04:38 AM
0/11 ssssss767
the prob with doing port back in those blazers is the back glass claps really bad ive heard of people cutting the latch ring from vibration. but it can be done pm ablemt he did it and he used a 12in aero if im not mistaken.
Old 02-27-2012, 05:19 PM
Im an Investment!
0/11 ssssss450
A 4 door has a better rear hatch and keep in mind mine has been abused for about 6 years now lol
Team D.O.A.
Old 03-14-2012, 08:14 AM
trf7196's Avatar
0/11 sssssss54
I'd do port back.
sub up port back in trunk? slamica General Car Audio Discussion & Questions 14 07-29-2011 11:34 AM
you guys with subs up port back..... RWatts General Car Audio Discussion & Questions 16 07-07-2011 12:02 PM
Subs back, port up bigoooee Enclosure Discussion & Design Construction Help 8 03-31-2011 05:32 PM
subs up port back or up??? rdminitrucker General Car Audio Discussion & Questions 20 12-30-2010 11:32 PM
Sub up, port back.... does the box have to be all the way back to be effective?? NorthBeat General Car Audio Discussion & Questions 5 08-01-2010 08:16 PM
