How close can a port end be to a wall? - Car Audio Classifieds!
Old 02-26-2012, 11:33 AM
0/11 sssssss93
Default How close can a port end be to a wall?
I'm wanting to put an aero port on the same face as my sub but I'm not sure if I have enough depth. Can a aero port end be closer to a wall than its diameter? My port end would be 3" away for a 6" flared aero port. It would be in the center of a 20" deep box so it wouldn't be in a corner. Would this be choking the port??
Old 02-26-2012, 11:42 AM
Veteran Member
0/11 sssss3359
ideally no.
Old 02-26-2012, 11:45 AM
nicholask1993's Avatar
Dubstep Addict
0/11 sssss1802
I've always been told that it's supposed to be at least port diameter away from any wall...
1998 Subaru Forester
Sony CDX GT-565UP Head Unit
Cadence 6.5" Components
MB Quart Onyx 1500.1
/Surreal
Old 02-26-2012, 11:48 AM
Veteran Member
0/11 sssss3359
that is correct. an aero port is still just a port and you want to be at least the diameter away.
Old 02-26-2012, 11:56 AM
0/11 sssssss93
Damn back to the drawing board. Thanks guys
Old 02-26-2012, 12:57 PM
mega fatty
0/11 sssss6008
I've seen people do 1/2 port diameter away from a wall with slot ports
But I'm sure having it atleast the diameter is ideal
07 mazdaspeed3
rd d9 @ .5ohm
Old 02-26-2012, 01:04 PM
sthrnbumpn's Avatar
0/11 sssss2961
Feedback Score: 21 reviews
it limits the excursion on overpowered applications when you place them 1/2 the diam away
Old 02-26-2012, 01:07 PM
Pioneer~Saturn's Avatar
Idk what Im talking about
0/11 sssss8346
I always like to keep around 'ports width/dia' away from a solid surface but a smidge closer wouldnt be the end of the world, I would try and keep it close to the port width/dia away tho...you can always experiment too, maybe your certain situation may perform better a certain way.
Louder. Lower.
Team Tupperware
has anyone gotten a 4 door cavalier loud close to 150 with out a wall cav950015s General Car Audio Discussion & Questions 8 02-15-2012 04:57 PM
Friendly Face-Off! No Wall Low End Monsters Enter!!!! twistedchild420 General Car Audio Discussion & Questions 20 06-18-2011 02:08 AM
port vs. wall oslouie General Car Audio Discussion & Questions 12 02-21-2011 11:33 PM
Help with a BP, slot port or square port for 2nd row 4th order bandpass wall 46panel General Car Audio Discussion & Questions 7 08-24-2010 09:32 PM
Where to put port in a wall orangelss General Car Audio Discussion & Questions 10 07-21-2010 09:55 PM
