Hows this look? - Car Audio Classifieds!
Old 06-10-2009, 07:09 PM
0/11 ssssss165
Default Hows this look?
how does this look?
Used the RE calculator and it is confusing me a little bit. It is saying 4.58ft^3 volume with 105 sq.in. of port but when i do the math I get the volume shown in the box (in the drawing)... Sayd the tuning is 42Hz~ which is exactly what I am looking for but I wanted to make sure everything is good since I am getting conflicting numbers on teh box volume...
Box is for a Mach5 SPL15
Old 06-10-2009, 07:27 PM
strpperpolef150's Avatar
Ladies love my pole
0/11 sssss3814
The RE calculator is not that accurate. I would throw it into bbp for you to check but Im about to jump in teh shower.
-Single cab F150-
HU: Kenwood KDC-X993
Processing: Clarion EQS746
Front stage: (2x) Shok CB 6.5
Comp amp: Crescendo 1000C4
Sub stage: (2) AQ HDC3 10s in 2.3 cuft @ 38hz
sub amp: (2) SAZ-2500s strapped @ 1
Electrical: Mike Singer 250a alt, D3100, (2) NSB90, 70+ft of shok
New numbers coming soon.....
I buy shifted motors
- Team PSI - Team Shok -
Louisiana/Mississippi Crescendo Rep
Old 06-10-2009, 07:58 PM
0/11 ssssss165
Well, If you get the time later I woud appreciate it... No reall hurry, not planning to build it for a couple days yet so....
Old 06-10-2009, 08:25 PM
lantz's Avatar
0/11 sssss1030
damn thats a long shower...LOL!! i always confuse myself everytime i make a ported box.i end up texting alanhall about 50 times...lol! sometimes i think its worth just paying somebody else to design it but that just takes the fun and self achievement out of it.
Old 06-10-2009, 10:37 PM
0/11 ssssss165
Usualy I pay... However I set myself a monthly budget for car audio and have almsot doubled it already this month and it isn't even half way through the month so.... Only thing i can buy now is the sheet of MDF for my box.
Old 06-10-2009, 10:43 PM
forceww's Avatar
0/11 sssss3264
i get around 47 hz when i do it?
ANOTHER New System
Team SBC-Team CACO-Team Lethal Beatz
plenty of refs just ask
Old 06-10-2009, 10:48 PM
0/11 ssssss165
HHHMMM.... that is a little higher than I want... 42hz~ is what i am looking for... I'll see if may be some others "crunch the numbers" and come up with the same...
Thank You for your input!
Old 06-11-2009, 12:39 AM
Ladies love my pole
0/11 sssss3814
ok I put it these dimensions:
36W x 16.5H x 22D
Port: 7W x 14.5H(1.5" - 16.5) Tuned to 42hz
I got a port length of 23" and a volume of 4.812 w/o sub or bracing displacement.
That design with the port at 13.5H x 7W x 15D is 5.32 cuft @ 45.26hz w/o sub or bracing displacement.
Neither designs had double baffle. I can add all of those things in to get real numbers if you would like.
-Single cab F150-
Old 06-11-2009, 09:36 AM
0/11 ssssss165
If you wanna toy with it more that is up to you... port has to be 15" high though as that is the inside height of my box...
Since the displacement of the sub and bracing, would that lower the tuning or raise it? I gifure the subs will be a good .2ft^3 or so and then the 45*s in the corners, bracing will just be a 1" dowel...
Old 06-11-2009, 04:23 PM
Ladies love my pole
0/11 sssss3814
O oops I miscalculated that height lol Im at work now but Ill see what I can do later on.
-Single cab F150-
Hows it goin? keysersoze845 New Member Orientation 12 06-03-2009 11:00 AM
hows this sound brtnboarder3241 General Car Audio Discussion & Questions 10 06-02-2009 08:53 PM
hows this look korey_hofer General Automotive Chat 2 04-28-2009 10:21 PM
Hows everyone bdufner New Member Orientation 14 01-05-2009 08:00 PM
hows it feel? SPL Guru Off Topic Chat 15 10-16-2008 12:01 AM
