2 door blazer - Car Audio Classifieds!
Old 03-05-2012, 08:58 AM
0/11 sssssss68
Default 2 door blazer wall?????
currently i have 2 sa 15s in roughly a 4 cubic foot box. the reason for making this so small was to stay below window line for competing. i have been researching designs for my next set up which will be 2 dc audio lvl 4 or xl 15s on 3.5k. to get the suggested air space for these drivers i would no longer be able to stay below window line with sub up port back because id like to stay 6 inches away from the back hatch so the ports to load off the hatch. my only other choice is to build up as in build a taller box which would be above window line so i was thinking of just walling it at the c pillar so i will be able to keep my back seats. so my question is what are the pros and cons of a wall vs. a taller sub up port back box. i've already put into consideration about what will have to be done for bracing to make the box not move and for flexing purposes i would just like to know what you guys thought?
Old 03-05-2012, 03:16 PM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
There's way more than just 4 cubes while staying under the window line. Do 6 cubes with a single 8 inch aero in the center. Subs up port back. And make the box as wide as you can
Old 03-05-2012, 03:21 PM
0/11 sssss1564
Im pretty sure there was a new rule added that affected blazers in certain comps making it ok to go above window line as long as you are 13" away from headliner.
Because Blazers have a very low window line..
u scratchn ur ass or your head, but it could be both cause your heads in you ass.
Old 03-05-2012, 06:59 PM
0/11 sssssss68
where did you read that at? and i wanted to make it as big as possible but keep it 6 inches away from the back hatch
Old 03-06-2012, 09:47 PM
0/11 sssssss68
anyone else done this or have any imput?
Blazer sealed vs. Door open Xtremelegend General Car Audio Discussion & Questions 10 03-27-2011 08:07 AM
Blazer door panels + 10" mids????? EpicenterDesigns Miscellaneous Build Logs 55 12-12-2010 10:44 AM
wtb: 1998 chevy blazer 4 door front door panels bgaccord Wanting to Buy (WTB) 0 08-23-2010 10:02 PM
chevy blazer 4 door tuning? and other questions Hirschblazin General Car Audio Discussion & Questions 3 06-21-2009 06:45 PM
