1 chamber box or 2? - Car Audio Classifieds!
Old 03-07-2012, 10:45 AM
BASSNUT
0/11 ssssss180
Default 1 chamber box or 2?
I'm going to be putting 2 10's in my car and can't decide whether I should put both subs in one big chamber with one port out the front or give both subs a seperate chamber and port them seperately. I'd like some opinions and ideas and why?
Old 03-07-2012, 10:54 AM
OldSchoolRF's Avatar
0/11 ssssss741
I always prefer to use separate chambers when possible. I like to run each sub to it's own individual amp and by doing that it allows me to only play one sub if I want to. Plus with separate chambers if one sub blows you don't have to worry about damaging the second sub because of too much air space. I also think the box is more sturdy because of the added bracing the middle seperator provides.
Just my two cents though..
Old 03-07-2012, 12:13 PM
BASSNUT
0/11 ssssss180
Thats what my thinking has always been also, I'm only going to be running 1 amp though and i'm just wondoering if there'd be better output with both subs being in the same airspace vs. individual
Old 03-07-2012, 12:29 PM
nicholask1993's Avatar
Dubstep Addict
0/11 sssss1802
I honestly don't think there would be a noticeable difference in output. I would go with two separate chambers for the reasons above.
1998 Subaru Forester
Sony CDX GT-565UP Head Unit
Cadence 6.5" Components
MB Quart Onyx 1500.1
/Surreal
Old 03-07-2012, 03:12 PM
BASSNUT
0/11 ssssss180
I think i will do the seperate chambers then. One more question, would you suggest having the ports go to the outside or middle of the box?
Best Set of 10s for Sealed Box - 1cu ft per chamber grandprix17 General Car Audio Discussion & Questions 11 01-03-2012 09:43 AM
2 ports 1 common chamber? laextreme5 General Car Audio Discussion & Questions 11 10-29-2011 10:17 PM
Single chamber or double chamber? lance.requa Enclosure Discussion & Design Construction Help 4 10-12-2011 12:06 PM
Why are common chamber boxes louder? Dbmonster General Car Audio Discussion & Questions 13 12-01-2010 12:29 PM
