Help with TC/PSI 15" in trunk - Car Audio Classifieds!
Old 03-07-2012, 02:59 PM
infaredsinsor's Avatar
0/11 ssssss769
Exclamation Help with TC/PSI 15" in trunk
I just purchased on of these FS: Tc/PSI 15s ti baskets 8 layer coiland I need some help in box design. I can't decide how to do port(s). This is going to be a daily driver and I may play at local comps for shits and giggles. It's mostly daily though.
This will be done in a 2002 Honda accord. I have 17H X 30W X 22D to work with to still keep ideal space.
Subs, amps, and power
AFEX Fire Suppression Systems Quality Engineer
itrader info available on profile
Old 03-14-2012, 09:10 AM
trf7196's Avatar
0/11 sssssss54
I'd use a single 6" aero and tuned to 32 hz make sure the overall length is 14" if you use a PSP aero from parts express and the box dimensions will need to be 30x17x20.5 everything firing forward.
Old 03-14-2012, 12:11 PM
0/11 ssssss769
So do you think it will make any difference with the sub on top?
1 12" psi Platform 3 trunk car (Dodge Neon) MtxNeonguy937 Enclosure Discussion & Design Construction Help 0 08-06-2011 04:46 PM
12inch "TRF PSI combo woofer. 1000th build contest winner sub from PSI mrfantastic911 Car Audio Trader (WTT) 14 01-31-2011 05:06 AM
WWYD? Treo SSX 12" versus PSI Brahma 10"? Pillow General Car Audio Discussion & Questions 0 09-07-2010 11:39 PM
4 PSI 18S+25kw= EARGASM vid #3- "He knockin in that bish" 98HOEONSIXEZ Car Audio Videos 32 08-03-2010 11:07 AM
[Sold]4" coiled custom PSI 12" and extra motor F3M4 12" Subwoofers 20 04-12-2010 07:36 PM
