4th order help - Car Audio Classifieds!
Old 03-10-2012, 01:04 PM
Quite Northern Michigan
0/11 sssss1309
Default 4th order help
So I've decided to go with a 4th order for my 15" Omegas, and I need a little help. What is the common ratio used when designing these? Any idea on the ported and sealed cubic feet for these subs? Thanks!
Remember, the pain inside can't be fixed by something outside, all you can do is cover it up that way. It's totally an inside job.
Everything in life is a test. You always come out stronger on the other side.
Old 03-10-2012, 01:18 PM
46panel's Avatar
0/11 sssss1662
3:1, 2:1, 1.5:1 are probably the most common, most people I see go with the 2:1 ratio. Using 15's the sealed side is usually between 1.5-2.5 cubes per.
2007 Chevy Impala: JVC KW-V10, Sundown Nightshade 15", Planet Audio Big Bang 2400, Alpine MRP F450, JBL P660C components.
Old 03-10-2012, 01:46 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
Stop, this is a generalization.
I need vehicle, power, goals, etc.
Old 03-10-2012, 10:41 PM
0/11 sssss1309
Haha. '86 Volkswagen golf gti 2 door. 2500 watts a peice, loud daily. I listen to metal, and dubstep but like deep and low slowed music. I know those two dont go together... But anyways...
Old 03-10-2012, 10:43 PM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
Pleaseeee post pics of the car :]
Old 03-10-2012, 10:57 PM
0/11 sssss1309
How about tommorow, right after I wash and vacume it? Haha.
Old 03-10-2012, 10:59 PM
46panel's Avatar
0/11 sssss1662
When are you getting started on this thing man?
I'll be working on my 4th order probably this week
Old 03-10-2012, 11:02 PM
813thumper's Avatar
0/11 sssss1116
if you want lows then you need a large ratio tuned low.
I LIKE BUILDING ENCLOSURES FOR CUSTOMERS
Old 03-11-2012, 09:02 PM
0/11 sssss1309
I'm probabally going to start this week, or tommorow. At least on part of it. I still need to find another freekin omega motor.
Old 03-11-2012, 09:03 PM
0/11 sssss1309
4th Order vs. 6th Order? younggunzbass01 Enclosure Discussion & Design Construction Help 18 05-24-2011 04:34 PM
SA 8 4th order or 6th order? tez4life (Sundown Audio) 5 01-26-2011 11:08 PM
