Box placement - Car Audio Classifieds!
Old 03-13-2012, 01:48 PM
btsteinb's Avatar
0/11 sssss3573
Feedback Score: 30 reviews
Default Box placement
So new setup in my yukon is going to be a 9518, in the cargo area.
I have 4 4" aeros from an old bulid that i would like to use. They are 17" long which would result in a tuning freq of 34.5 hz at 6 cubes using psp calc, for daily, and ports would be interchangable to play up to 50 hz for burping. ports can be internal or external, makes no difference to me.
Just wondering what configuration of sub/port people have had success with, sub up / port back, sub firing passenger side / port up, ie. any suggestions on success you have had in your yukon/tahoe/suburban let me know. trying not to have to build 10 diff boxes, but if I have to I will, just looking for a starting point.
Old 03-13-2012, 01:51 PM
ddbump's Avatar
Loyal Member
0/11 sssss2385
Feedback Score: 17 reviews
Sub up port back I believe it best for dbdrag
1996 dodge ram 1500
-12 Tantric HD 15s
-4 AQ 3500.1s
_TEAM D.O.A_
_TEAM DTF_
Old 03-13-2012, 09:10 PM
duff_thrust's Avatar
0/11 ssssss629
Yep sub up port back. It seems to work the best. port across the bottom back of the box. I've tried a few configurations in my 99 tahoe and this has worked the best as for output as for numbers and music.
Old 03-14-2012, 08:14 AM
trf7196's Avatar
0/11 sssssss54
Sub up port back as others have stated will be your best bet.
Tags
aero port, aero port 18" subwoofer, digital designs, enclosure design, tuning
battery placement ?s scfaust General Car Audio Discussion & Questions 2 03-09-2012 09:14 PM
Sub placement in box billystorms24 General Car Audio Discussion & Questions 10 08-30-2011 04:03 PM
Sub placement help Boomintahoe Enclosure Discussion & Design Construction Help 7 08-18-2011 04:58 PM
sub/port placement? Ryan1126 General Car Audio Discussion & Questions 20 04-01-2010 05:45 PM
Sub and Port Placement Help undeadxsunshine Enclosure Discussion & Design Construction Help 4 03-27-2010 06:27 PM
