2 18" Fourth Order build this weekend-Tips before build - Car Audio Classifieds!
Old 03-13-2012, 07:33 PM
0/11 ssssss188
Default 2 18" Fourth Order build this weekend-Tips before build
Well I'm finally prepared to do a C-pillar wall in my 1995 Yukon, and I'm in search of any last minute pointers/tips before I start going at it on friday.
2 18 HDC3/PSI soft part subs
6K
I'm shooting for a peak in the 33/38hz range and I'd like a fairly flat response around 30-40hz. With the ability to still play stuff up to 45/50hz pretty loudly.
My max dimensions are 36x36x47 wide. Right now I'm planning on doubling up all walls and doing subs firing toward the drivers side with a slot port on the drivers side. 6/6.25 sealed into -+16cuft. Starting port area will be 275/280 inches of port in the 48/50 hz range, then shrinking it down a bit to get the low end I want out of it.
Here's my current idea
Uploaded with ImageShack.us
Old 03-13-2012, 07:41 PM
Dunbar91's Avatar
0/11 sssss6816
Feedback Score: 51 reviews
My tip before the build= stock pile some brews
The Following User Says Thank You to Dunbar91 For This Useful Post:
18inchjeepin (03-13-2012)
Old 03-13-2012, 07:47 PM
HACKMUNCH's Avatar
0/11 sssss3892
should work just fine, did one very similar a few weeks back but we used 3 15" same config. id have to look tru my notes but i think we did 285" port. what ever you tune it to peak will be aprox 3hz LESS than tuning.
TEAM TSA 2013
FACTORY BACKED
XS POWER - 4XSPOWER.COM
PSI - PSICARAUDIO.COM
Old 03-13-2012, 08:06 PM
treylittlefield's Avatar
0/11 sssss5201
Feedback Score: 37 reviews
For a 4th order?
Sent from my C771
2000 2dr Blazer
Old 03-13-2012, 08:20 PM
0/11 ssssss188
In wondering that too
Old 03-13-2012, 08:50 PM
HACKMUNCH's Avatar
0/11 sssss3892
yes sir, ive build 3 decent size 4th orders in the last 3 weeks. everyone peaked 3 to 4hz lower than tuning. if you do an impedence sweep of the enclosure ull see why.
TEAM TSA 2013
FACTORY BACKED
Old 03-13-2012, 09:02 PM
0/11 ssssss188
How was the bandwidth?
Old 03-13-2012, 09:23 PM
HACKMUNCH's Avatar
0/11 sssss3892
2 big factors of Bandwith is the qts of the drivers and the bandpass ratio. The Higher qts of sub the peaky it is and the higher the bandpass ratio makes it more peaky. So far I like the 2:1 on the higher qts drivers for music. On the lower qts drivers the bigger the ratio the better.
TEAM TSA 2013
FACTORY BACKED
Old 03-13-2012, 09:42 PM
Infinitelybaffled's Avatar
0/11 ssssss816
That's funny because I peak 5hz above my tuning. The peak is mostly vehicle / ratio dependent imo. I changed my tuning by 10hz and my peak freq went down 2hz. I changed my ratio from a 2:1 to a 1.67:1 and my peak dropped 7hz at the same tuning.
Inappropriate sig image.
Old 03-14-2012, 05:33 AM
HACKMUNCH's Avatar
0/11 sssss3892
do a impedence sweep and ull see why. your sealed side has a resonance, basicly where your impedence is the highest. your port tuning is to far from your sealed resonance. ull know when you get near your sealed resonance because your spl will increase dramaticly.
TEAM TSA 2013
FACTORY BACKED
fourth and or sixth order help imlouder Enclosure Discussion & Design Construction Help 0 01-13-2012 04:24 PM
sa 12 fourth order tuned to low? lilsoccersully Enclosure Discussion & Design Construction Help 11 01-07-2012 08:08 PM
six 12s fourth order in a neon? SPLEclipse Enclosure Discussion & Design Construction Help 2 02-15-2011 10:52 PM
Box Build this weekend need advice(s) super_duper Enclosure Discussion & Design Construction Help 19 01-22-2010 03:05 PM
2 18s in a fourth order in cobalt GODHATESCIVICS Enclosure Discussion & Design Construction Help 6 12-10-2009 06:23 PM
