2 hdc318s box for blazer - Car Audio Classifieds!
Old 03-16-2012, 01:07 PM
0/11 ssssss437
Default 2 hdc318s box for blazer
need help designing a box max measurements are 38 wide 36 deep and 35 high. any ideas going into a blazer 4 door , off a 3500d.
Old 03-16-2012, 01:13 PM
0/11 sssss1564
Spike131113's DC Soundlab Blazer
*MEASUREMENTS (in inches)
Total Width: 45
Width Between Tires: ~38
Depth: ~32.25
Height: 21.5
Inlet Height(over wheel wells/ batteries): ~8.5
Inlet Width: ~3.5
u scratchn ur ass or your head, but it could be both cause your heads in you ass.
Old 03-16-2012, 01:19 PM
0/11 sssss1564
That box is roughly 10.3 cubes after displacement.. tuned to 27Hz ... does a 150.8 off a 3.5k @ 0.5 ohm.. its a proven design
Old 03-16-2012, 01:25 PM
kevinN's Avatar
0/11 ssssss403
whats the peak at that 150? if its above 40 it should be doing much more
I run a single 18 in 6 cubes tuned to 36hz in my jimmy and I can do a 150...
Old 03-16-2012, 01:26 PM
kevinN's Avatar
0/11 ssssss403
thats not alot of area to work with for 2 18's, you looking for spl or daily?
Old 03-16-2012, 01:33 PM
0/11 sssss1564
Its a daily driver, tuned to 27Hz, with 1300 clamped watts... Personally I think thats a decent number.
Old 03-16-2012, 01:37 PM
kevinN's Avatar
0/11 ssssss403
Im tuned to 27Hz on a daily driver, if your after numbers than idk what to tell ya than besides editing your original post so people know what you want
Dude Im not the OP, just a jimmy owner with a single 18
Old 03-16-2012, 01:40 PM
0/11 sssss1564
My mistake.. but still
Old 03-16-2012, 01:43 PM
0/11 sssss1564
Im not trying to hype up doing a 150 with 2 18s. Just giving the score as a reference to how loud it is.
Old 03-16-2012, 01:46 PM
kevinN's Avatar
0/11 ssssss403
gotcha
box help for blazer skartisu Enclosure Discussion & Design Construction Help 6 11-19-2011 11:10 PM
2 hdc318s walled in a maxima agog86 General Car Audio Discussion & Questions 19 10-11-2011 11:05 PM
Blazer box help!!!! LyferXB9s Enclosure Discussion & Design Construction Help 16 10-09-2011 12:30 PM
15" DC XL in a Blazer help with box!!!!!!! dj00140 General Car Audio Discussion & Questions 0 09-16-2010 05:11 PM
Hmmmm 4 sdc2.5 subs on 2 aq1200ds or 2 hdc318s on 2 aq2200ds Mgcauctions09 General Car Audio Discussion & Questions 9 04-06-2010 02:08 AM
