Critique my box build - Car Audio Classifieds!
Old 03-16-2012, 01:55 PM
0/11 ssssss161
Default Critique my box build
Alright about to build a box and just want to verify all my specs and math, appreciate all the assistance ahead of time!
Car is a 06 Scion Tc
Running a SAZ 2500 on a single DD9515h carbon fibre cap
The box I'm looking at building is
Wedge shape, sub facing up, ports up
37.5" width
16.5" height (closest to headunit)
11.5" height (closest to hatch)
21" depth
1" thick mdf (opinions on whether I should use 3/4?)
comes to 4.68 cu at 1" thick
two 4" aeroports (11.37" long for 33hz and 7.11" for 40hz)
Now I don't know my subs displacement, so I should figure that out and take it out of my volume and reconfigure the aeroport length correct?
Anyways how does everything sound to you guys, what would you do different?
Old 03-16-2012, 02:01 PM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
37.5" width
21" depth
Use 3 4" at 18" long each or 1 8" at 21" for 33hz. You can buy them here from Derrick, he makes 4", 6", and 8" aeros with flares.
Old 03-16-2012, 02:05 PM
0/11 ssssss161
what difference would there be using a single 8 verses three 4's?
Sent from my HTC_Amaze_4G using Tapatalk
Old 03-16-2012, 02:07 PM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
The 8" has more port area.
I would go with the 3 4" tho. And make sure the ports are always AT LEAST the diameter of the port away from the back wall
Old 03-16-2012, 02:10 PM
0/11 ssssss161
If they need 18 inches each I don't know how I will face them up (any other direction is right against a wall)
Old 03-16-2012, 02:13 PM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
Have half of the port in the box and the other half outside
Old 03-16-2012, 02:20 PM
0/11 ssssss161
only got like 3-5 inches until it hits glass haha.. hmm so two 4" is completely different than one 8"? I understand three fours being a total of 12" of port space
Old 03-16-2012, 02:46 PM
0/11 sssssss69
2x2x3.14=12.56 area of 4" port,12.56x3=37.68 area of 3 4" ports
4x4x3.14=50.24 area of 8" port
radius x radius x pi =area
Old 03-16-2012, 03:31 PM
0/11 ssssss161
Ahhhh that's right we are taking cyclinders.. forget what I learned in school haha. Here is my dilema, the maximum length of the ports I can do is around 9 to 14, 14 being a single port and 9 being multiple ports. Any suggestions to get the most port area?
Old 03-16-2012, 03:54 PM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
single 6" at 13"
need critique on first box desgn KCowboy620 Enclosure Discussion & Design Construction Help 11 01-13-2012 06:04 PM
2 12s 4th order design critique Kelocyde Enclosure Discussion & Design Construction Help 26 12-06-2011 07:49 AM
Please critique my resume. rideit Off Topic Chat 1 05-25-2011 02:21 AM
deepsilencer's new box build video designed by james(A.I),build by 99s10walled deepsilencer Car Audio Videos 1 08-30-2010 02:43 AM
Critique? F3M4 Enclosure Discussion & Design Construction Help 19 09-30-2008 11:47 PM
