attn fourth order wizards... - Car Audio Classifieds!
Old 03-16-2012, 09:46 PM
0/11 ssssss384
Default attn fourth order wizards...
Before i open myself to a condescension contest, lemme start by saying that I have in fa t used the search function furnished us by the site to try and answer my own question, but apparently im a retard. That said, im about to try my first fourth order but I understand some drivers really dont respond well in them. All i have that I can run in the experimental box is a DD 3515. Waste of time or go for it?
Old 03-16-2012, 09:48 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
3515 is going to be more suited for a 6th order. You want to generally use woofers with a lower ebp for a 4th order.
Old 03-16-2012, 09:49 PM
Skip01's Avatar
Ladies MAN
0/11 sssss5551
Just port it......itll wreck
Youtube VIDz :
Old 03-16-2012, 09:53 PM
0/11 ssssss384
Holy jeebus Buck that was quick! So this sixth order you speak of... any chance you got design tips for one of those?
Old 03-16-2012, 09:54 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
I can design one for you if you like. Pm me if interested.
Old 03-16-2012, 09:56 PM
mega fatty
0/11 sssss6008
im with skip, ported is simple and effective
ive seen them run from 3.5-5cf tuned to 35-39 for a solid music box, i would try 1 6" aero for daily is let it wang
and what kinda power?
07 mazdaspeed3
rd d9 @ .5ohm
Old 03-16-2012, 10:01 PM
0/11 ssssss384
I appreciate the interest already but I guess the point I was getting at was I wanted to try a different type of enclosure for experience sake, but am limited in driver selection. That said, sixth order enclosures are every bit as foreign to me as fourths, so Ill pm you shortly buck.
Old 03-16-2012, 10:03 PM
mega fatty
0/11 sssss6008
how much room are you willing to give up?
what kinda car?
power?
music type?
07 mazdaspeed3
rd d9 @ .5ohm
Old 03-16-2012, 10:10 PM
0/11 ssssss384
Ty, its gonna be in an 03 impala, max od of 36x30x17. Itll be on an m3a @2 or. 5. And ill jam anything but country.
Old 03-16-2012, 10:22 PM
mega fatty
0/11 sssss6008
you should have enough room for a 6th then, see what buck can do for you and give it a shot, i would seal off and port through the rear, or put the seat down
07 mazdaspeed3
rd d9 @ .5ohm
fourth and or sixth order help imlouder Enclosure Discussion & Design Construction Help 0 01-13-2012 04:24 PM
sa 12 fourth order tuned to low? lilsoccersully Enclosure Discussion & Design Construction Help 11 01-07-2012 08:08 PM
Crazy Hairs fourth order question llacrazyhair Enclosure Discussion & Design Construction Help 0 01-04-2012 09:39 AM
six 12s fourth order in a neon? SPLEclipse Enclosure Discussion & Design Construction Help 2 02-15-2011 10:52 PM
2 18s in a fourth order in cobalt GODHATESCIVICS Enclosure Discussion & Design Construction Help 6 12-10-2009 06:23 PM
