square port question - Car Audio Classifieds!
Old 03-18-2012, 05:52 PM
0/11 ssssss437
Default square port question
2 hdc3 18s in a 11.5 cu ft box after displacements need a square port not a slot port. Have no idea how to figure out port area. Was wanting to tune to 33hz any help please.
Old 03-18-2012, 06:15 PM
gibsonm21's Avatar
0/11 ssssss392
L x W to determine the area. You probably want to stick to 140 - 180 sqin of port.
"WHEN you're thinking of replacing a blown fuse with a higher rated fuse ask yourself if you know more than the engineer who designed the equipment."
Old 03-18-2012, 06:24 PM
0/11 ssssss437
so a 13x13 port would be how long to tune it to 33hz? or a 14x14 how long would they have to be?
Old 03-18-2012, 06:41 PM
0/11 sssssss60
Subwoofer Enclosure Calculators, Fraction to Decimal, Parallel, Series, Port Length and Volume Calculators
Helps me out a lot
Need help calculating square port joshua1davison Enclosure Discussion & Design Construction Help 0 03-13-2012 06:16 PM
Square Inches of Port?What's Optimal? Jdubs04ss General Car Audio Discussion & Questions 1 02-03-2012 07:27 PM
Help with square port size and tuning taylorpro Enclosure Discussion & Design Construction Help 0 09-20-2010 10:29 PM
round port converted to square port Ryan1126 General Car Audio Discussion & Questions 4 04-12-2010 03:46 PM
